Help!! Something wrong with my scoops.. |
Post Reply | Page <1 5678> |
Author | ||||
bee
Old Croc Joined: 14 June 2011 Location: Middlesex Status: Offline Points: 4553 |
This subject has been talked about to death on hear. A new basket design. but the is a slight depth change if you put both side by side its clear to see.
JR.junior
Old Croc Joined: 14 December 2009 Location: Slovenija Status: Offline Points: 1789 |
tell me, which one is better as 1850?
bee
jr junior you have a pm... |
luton_soundman
Old Croc Joined: 03 August 2010 Location: Bedfordshire Status: Offline Points: 4538 |
Thing is after all the negative talk me and hundreds of others have heard a certain sound with the newer 50/2 and sounds great, throw, pressure everything. Maybe it was just the really early batches that were bad?
toastyghost
Or just people dropping them into boxes without paying heed to the parameters and whether they would be a good fit. |
levyte357-
People I know who tried early 50/2s, said they were unhappy, because they were told they would perform the same as the Series 1 (PD1850MK2, black label), and they didn't in the same box.
Not tried new 50/2 in suitable box, so who knows? |
luton_soundman
Iirc wasn't everyone told the parameters were the same? (Don't quote me as im not 100% sure but more 95%)
bee
originally yes, then they relased the update parameters. I took my own readings on 3 versions of the 1850, the original, then the later model then the new model (/2). Interestingly none were even close to each other...
toastyghost
That's not exclusive to PD. Or uncommon. There's such a thing as manufacturing tolerances. Buy two drivers off anybody and measure yourself...
levyte357-
That's quite true. But obviously, if 2x different "Series 1", PD1850 Mk2 Black label drivers work in the same box, and the Series 2 doesn't, that "implies", the Series 2 driver parameters, are way off, from the "Series 1" drivers. |
levyte357-
The Logical answer to the 1850/2 shenanigans, would be for unbiased party, to correctly measure parameters of at least 3x different late 1850/2, and do the same for 3x different "Series 1", PD1850MK2 black label drivers, (after purchasing them from the Rocking Horse Poo shop), and tabulate results openly.
RoadRunnersDust
Young Croc Joined: 03 December 2013 Location: United Kingdom Status: Offline Points: 560 |
I think you are all getting FAR to caught up over driver specs that you have forgotten that the most important aspect of the sound is the colour of the cab...
Edited by RoadRunnersDust - 16 July 2016 at 7:32pm |
