help with horn design cerwin vega 189es |
Post Reply | Page 12> |
Wigge
Registered User Joined: 18 October 2004 Location: Sweden Status: Offline Points: 12 |
Posted: 12 February 2005 at 7:41am |
hi! i have 8 old cerwin vega boxes i think they are called b48 its a w bin 60cm high 60cm deep and 120cm wide they work fine from 50hz and up but i want more deep bass and i think there was a bigger version out with same driver that worked better under 50hz.. so now i ask is someone could help me calculate a new horndesign or might have plans that those drivers schuld work good in with more deep bass atleast down to 35-40hz.. normaly i use them in pair of 2 parameters cerwinvega 189es fs 30.5 hz qms 3.86 vas 244l cms 0.1514727mm/n mms 179.76g rms 8.9248kg/s xmax 5.2mm sd 1065cm2 qts 0.227 spl 96.7db 1 w/m qes 0.241 re 5.0 ohm z 8 ohm bl 26.73 tm pe 500 w
hope someone could help me out:) Wigge
JD01
Young Croc Joined: 23 August 2004 Status: Offline Points: 819 |
4 of them per stack should already give you 35-40Hz. If not, Cervin Vega just did another boom box again. Much output around 60Hz, nothing below, not much above then....
_djk_
"4 of them per stack should already give you 35-40Hz. " How could they possibly? The air path length is on the order of 4', looks like 64hz to me. |
djk
Old Croc Joined: 02 April 2004 Location: United States Status: Offline Points: 5176 |
I have four of those same boxes you are reffering to, in
a basement collecting dust. You can either; 1. Vent the box to get more extension. 2. Sell them 3. Build the larger version to it (48x 48x 24) However, you might as well build the lab horn if thats the case. I chose 1, vent the box. The speaker itself will not offer any sub bass even if you build a larger horn for it. The 189 ES, is a product of 1976, and, focuses on music purtained to 1976. Once I vented the box, I was - 3 dB @ 50 Hertz, opposed - 10 dB @ 50 Hz using one box. All you need to do is build new removable panel where you would insert the speaker in the box, and make a vent in the new panel. With the four boxes vented, I can easily get down to 40 Hertz. If you are want lower than 40 Hertz, build four labs, or go Reflex. Best Regards. Edited by Elliot Thompson |
JD01
_djk_: As I said, 'if not, CV just did another boom box'. I don't know how the path inside the box is, but from the size I thought that they have given it a bit of low end. Most CV horns are 60cm wide 90cm high and either 60 or 90 deep. And most of them are boom boxes with big hump around 60Hz. There are exceptions like the T36 which play really good from 30 Hz up in stacks of at least 4.
JD01
Its a W Bin. |
_djk_
"I chose 1, vent the box. The speaker itself will not offer any The Qts is too low to get any real bass from venting. Build up some of these, they will work fine with the CV 189: http://www.speakerstore.nl/index.php?l=nl&pg=11&c=18 My empty CV B48s went to the landfill in 1978. |
djk
freddyi
Registered User Joined: 22 September 2004 Status: Offline Points: 936 |
- played bass though PV's version - 64Hz was just fine - who wants to
bang on open E all nite? - -Traynor's short single path
"horn" for YBA3 looked kooler & sounded OK in pairs with the 100W
top and Fender - (I had those metalnecks)
_djk_
Bass guitar isn't the real problem. A few years back Stereophile did a spectrum analysis of a Fender P-bass playing an open 'E'. The second harmonic, E2, was 9dB louder! Drum kit likes to see 50hz if possible. 40hz tuned reflex boxes can cause a cone excursion problem here. Kill the keyboard player. Actually, he likes being heard too. If you explain the problem to him, he can find stuff that sounds good on your trash PA, and play some 'missing fundamental' games if need be. |
djk
Wigge
hello i have tested the driver in other horn boxes with more subbass out put so i donīt see the problem to use the driver below 50hz.. they used this driver in the old earthquake cinema boxes and they went deep? one more thing one more problem with the old b48 boxes is that they have started to give much "box noises" its on its way to fall a part that also why i want to build new boxes... thanxs Wigge
The driver used in the larger box was the 188 EB. (QTS 0.29)
A driver like yours is not going to give you a lot of Subbass under 50Hz. It wasn't designed to do so. (QTS 0.22) Subbass requires a QTS of 0.3 or more. Many use QTS 0.2 for subass, but, they have a large xmax. Where as the 189 ES is too small. Since the boxes, are totaled, why don't you just sell everything and build from scratch, and, buy the right speakers for the job. Thats the most I can tell you. Best Regards, |
Wigge
from the begining 188eb was made only for reflex system like b-118 a small bassreflex system with good responce/output i think you mean 189je it has much more bl (around 40) and lower qts like 0.15-0.17 Wigge |
