  New Posts New Posts RSS Feed - help with speakers
help with speakers
2x18 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2x18 Quote  Post ReplyReply Direct Link To This Post Topic: help with speakers
    Posted: 07 October 2009 at 4:40pm
hi everyone
im using 2x g-subs (2x 18"s) per side  with 1  2x12" per side , mid cab above it crossover at 120hz loads of sub no kick bass ?
what do you recomend please
2x15" on top the g-subs ?
thanks
just a old dj
DjMidKnight View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DjMidKnight Quote  Post ReplyReply Direct Link To This Post Posted: 07 October 2009 at 5:20pm
thats my plan is a dual 15 reflex on top of my gsubs.
bass*en*mass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 07 October 2009 at 5:27pm
if your two 12" have enough steam i would try to crossover lower so you get bass from g-subs and kick from 12", would say around 80hz should be fine with most 12s?!
just have a try with different crossovers and look if it gets better or worse.
cheers
p.s. whats the tuning of the 12er kicks? might be too high or too low aswell...
darkmatter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darkmatter Quote  Post ReplyReply Direct Link To This Post Posted: 08 October 2009 at 12:11am
What sort of EQ are you using? I imagine you'd need some 'baffle step compensation' i.e. something to approximate a 5-6dB/octave rising slope below around 300hz. Are you using any delay? Unless the crossover filters are steep it's possible there may be some cancellation around the crossover point without delay.
2x15" on top of the G-subs would be good and it'll raise stack height nicely :)
