  New Posts New Posts RSS Feed - Here's a Weird One for You!
Message Reverse Sort Order
RosietheBand View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RosietheBand Quote  Post ReplyReply Direct Link To This Post Topic: Here's a Weird One for You!
    Posted: 31 July 2010 at 5:10am
Thanks for all of your replies! You've given me a lot to think about.
I'm intrigued by the prospect of a stereo keyboard amp. The KP200s looks fantastic! It has a subwoofer output so I could make myself a nice 18 sub (I really want to make something :D). The problem is I cant find anywhere to buy one! I couldn't even find a price (I suspect it will be painful). Does anyone know of a UK supplier?
fuzzylogic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fuzzylogic Quote  Post ReplyReply Direct Link To This Post Posted: 31 July 2010 at 1:52am
I know of someone using the fane handbook 2x12 hornloaded long throw design for his synth... apparently with good results...???
Probably like a bishop bashing his organ... type of sound I was thinking.
NEIGHBOURHOOD SOUNDSYSTEM
Centauri View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Centauri Quote  Post ReplyReply Direct Link To This Post Posted: 31 July 2010 at 1:11am
Originally posted by subharmonics subharmonics wrote:
Originally posted by Dougies Music Dougies Music wrote:
All mono amps in my opinion sound SHIT -
Is that a technical phrase?
Maybe an acronym for "Seemingly Has Inferior Tone" ??  Big smile
subharmonics View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote subharmonics Quote  Post ReplyReply Direct Link To This Post Posted: 30 July 2010 at 10:28pm
Dougies Music View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dougies Music Quote  Post ReplyReply Direct Link To This Post Posted: 30 July 2010 at 7:47pm
I'm a keyboard player and have searched high and low over the years for a decent combo amplieifer.
They are few and far between - Keyboards sound choked through mono amps - stereo is the ONLY way to go.
BUT, there is a company that specialises in keyboard amps - for that budget, you could do worse than to check em out..
I own the KP 200-s and it is by far the best keyboard amp I have ever played through, and I've played through a lot....
sKs01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sKs01 Quote  Post ReplyReply Direct Link To This Post Posted: 30 July 2010 at 7:05pm
1 or 2 15's 10" and a 1" would be my recomendation, specifically if budget will allow...
BMS 15n850v2
Beyma 10MI100
BMS 4552nd
the above seem like they would be quite a nice combination
speak to Tony Wilkes about BMS as he is the UK distributor the prices as i remember it are rather good and the quality of the components is exceptional as is beyma which you can get from bluearan.co.uk having much more than that and it becomes rather impractical.
as to the amps peavy have just brought out a new lightweight budget line which is cheap and looks quite good on a scope for the mid and top and a second hand berry ep2500 can be had for bugger all for the 15's.
samwills View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote samwills Quote  Post ReplyReply Direct Link To This Post Posted: 30 July 2010 at 5:55pm
if you want cheap amps then the berry ep series are fairly reliable or the cpc pulse amps have been trialed and tested by a large p.a company and are standing the test of time against crown amps (obviously dont sound a sweet but reliability is always important)
Post Options Post Options   Thanks (0) Thanks(0)   Quote samwills Quote  Post ReplyReply Direct Link To This Post Posted: 30 July 2010 at 5:52pm
if your syth device such as keboard or w.e has a standard jack out put that normaly goes through a p.a then you could just go into a di box and then out in to a p.a or in your case (posibly go into a bass amp or into a standard power amp and set the level via pads on the di box and use say a 15" full range speaker as a bass cab) what do you think guys on here would it work if there's no preamp from a desk etc.. or you could use a small rack mount mixer to ensure that you can always set a level so you dont clip your amp.
So would go from synth/bass into DI-box then into small mixer into amp into fulrange speaker (sounds complicated but could be wired in to a 4unit rack so you would just plug in turn on connect synth and jobs a gooden..
Hope that helps.(would probs be better to get a p.a but its one way of getting round it)
puresoundglasgow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote puresoundglasgow Quote  Post ReplyReply Direct Link To This Post Posted: 30 July 2010 at 9:46am
If you want an easy solution you could always buy a Peavey KB300 or something similar, less likely to overpower guitar backline etc. than a massive custom built job.
Otherwise it sounds more like you need a decent pa system rather than huge synth bass backline !
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 30 July 2010 at 9:13am
So I'm assuming your synth bass comes from a keyboard player, so what's you're after is a big full-range keyboard amp?
While the design needs updating, you're probably looking at something along the lines of the DM2 on Plans section of the site.  Do you want to make it all in one box?
Amplification-wise you could probably get away with a Behringer Super-X crossover and an EP4000 (or a suitable second hand amp, which we might be able to help with!)  Run the two 15's on one side of the amp and whatever midrange and high frequency components on the other side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RosietheBand Quote  Post ReplyReply Direct Link To This Post Posted: 30 July 2010 at 3:52am
Hello! I figured I should probably put this in the newbie section (mostly because I have no idea what I'm doing Smile).
My band (www.rosietheband.com) doesn't have a bassist, we use synth bass. As we don't use a bass guitar we often have trouble doing smaller/less professional gigs, the ones that rely more on amps that a PA (they always end up being in huge rooms too) so I'm looking to build a "synth bass" amp.
I know I could just build a PA, but this sounds far cooler.
So here's the plan (ahem):
Budget £600 - £800 (tell me if that's stupid).
I have access to birch ply and a rather good engineer so that's all sorted.
I'm not sure whether to go for 2x18s or 2x15s (or 4 if the budget will allow!).
It will also need horns and midrange of some kind.
Amps - I know it's bad, but I was probably going to go behringer, unless anyone can suggest something else in that budget. As you can tell, I'm going for volume/cool factor over quality Big smile
As for the enclosure, I suspect it will pretty much end up being a PA system glued together, with some amps taped to it... on wheels.
If anyone has any ideas feel free to throw them at me ("this is completely stupid" is a perfectly valid idea by the way). It would be greatly appreciated Smile
Forum Software by Web Wiz Forums® version 10.10
