  New Posts New Posts RSS Feed - High qts driver in a Mini-Scoop?
audiofun View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote audiofun Quote  Post ReplyReply Direct Link To This Post Topic: High qts driver in a Mini-Scoop?
    Posted: 20 October 2016 at 7:50am
Hi All, Sorry for writing with no proper spacing... just had an accident with wine and my keyboard, the Enter button does not work :/  So, I would be very grateful for opinion from someone who has experience with the mini-scoop (ms-18 mk3). The question is: would a driver with qts=0.43 work well in that enclosure? The driver is a Faital 18Hp1030.
THIELE & SMALL Parameters
●    Resonant Frequency (fs) 35 Hz ●    DC Resistance (Re) 5 Ohm ●    BL Product (BL) 24.3 N/A ●    Diaphragm Mass inc. Airload (Mms) 228.6 grams ●    Mechanical Compliance of Suspension (Cms) 0.085 mm/N ●    Rms 4.46 Kg/s
●    Electromagnetic Q (Qes) 0.44 ●    Mechanical Q (Qms) 11.6 ●    Total Q (Qts) 0.43 ●    Compliance Equivalent Volume (Vas) 5.88 ft, 166.4 dm ●    Surface Area of Cone (Sd) 182", 1174 cm
●    Maximum Linear Excursion (Xmax)* 12.45 mm ●    Xdamage** 23.1 mm ●    Coil Inductance (Le) 1.37 mH ●    Diaphragm mass (Mmd) 205.8 g
●    Eta Zero 1.67 % Notes
Thanks!
patryk1305 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patryk1305 Quote  Post ReplyReply Direct Link To This Post Posted: 20 October 2016 at 11:24am
Fun Fact: There are two Enter keys on a standard keyboard Embarrassed
Post Options Post Options   Thanks (0) Thanks(0)   Quote audiofun Quote  Post ReplyReply Direct Link To This Post Posted: 20 October 2016 at 4:56pm
Yeah, I'm on 13" notebook, no second enter button. Anyway, any advice on the subject please?  Maybe, by the specs of the mentioned Faital woofer someone could suggest a good box for it? It needs to be a general purpose sub. Cheers, Tom
levyte357- View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 20 October 2016 at 5:01pm
fs 35 Hz
Qes 0.44
Qts 0.43
BL=24.3
Eta Zero 1.67 %
All tells you, this driver is  more suited to a Reflex cab.
Post Options Post Options   Thanks (0) Thanks(0)   Quote audiofun Quote  Post ReplyReply Direct Link To This Post Posted: 20 October 2016 at 8:08pm
Thank you Levyte. End of the story :)
