Highest amplifier supply rails? |
Post Reply | Page <1234> |
M4trix
Registered User Joined: 23 June 2009 Location: Croatia Status: Offline Points: 445 |
Ecler's PAM 6100 is a class AB amplifier with two 3,6kVA toroidal transformers, cca. 150V DC per rail and delivers 1750W per channel on 4 ohms load. That's the highest power supply voltage I've seen in a AB class design. It has 24 switching fets in the output, IRFP360. |
kedwardsleisure
Some of the big Trace Elliot bass amp heads use around 630V. I don't think this is a good idea!
North Staffordshire |
BUZguy
Registered User Joined: 17 November 2011 Location: South Wales Status: Offline Points: 478 |
I think the Maplin 1Kw and the BK Electronics 1000w module were both approx +/-90v.
studio45
630v with solid state devices? Really?
Nitz V1505
Old Croc Joined: 16 September 2009 Location: UXBRIDGE Status: Offline Points: 1719 |
& THE TOPS LIKE LIGHTNING..... |
Nitz V1505
kedwardsleisure
Yeah I was thinking of the V8 that uses 4 matched pairs of KT88. Serious stress and the valve bases coated in silicone grease.
Nitz V1505
Would love to hear it hooked up to a G sub or two loaded with Fane 18xb's!!!!!!!
DjLeco
Young Croc Joined: 21 April 2009 Location: Bucharest Status: Offline Points: 817 |
I use on mine modules of amplification, +/- 96-98Vdc
AB-B Class module amps.
Test here:
Peter Papp [PKN]
Registered User Joined: 17 June 2010 Location: Budapest Status: Offline Points: 203 |
There is no available circuitry which would be able to use 100% of the DC bus range.
Generally there is at least 5V or more drop due semiconductors, coils and ripple,etc.. effects. Edited by Peter Papp [PKN] - 08 March 2012 at 5:56pm |
M4trix
You burnt the floor with those dummy load resistors. Edited by M4trix - 08 March 2012 at 7:18pm |
DjLeco
Yes!
That means POWER.
Also dummy load was almost destroyed (melted ceramic)
Power is power, but at me is CONTINUOUS power!
