hill audio amp i found today :) |
Post Reply | Page 12> |
AUDIO HABIT
Old Croc Joined: 15 June 2009 Location: Manchester Status: Offline Points: 3383 |
Posted: 01 June 2010 at 7:44pm |
found this today and saved it from the tip,does anyone have any info on it,as it dont say much anywhere
thanks
mike
The Builder
Old Croc Joined: 03 January 2010 Status: Offline Points: 3107 |
I think that's an LC, check fuse size against info on panel.
Edited by The Builder - 01 June 2010 at 7:47pm |
It just is.
AUDIO HABIT
thanks mate,yeah i have done that and it would seem its a LC 800,as the fuse say F6.3 although the info panel says T6.3 for it to be an LC800 but i guess it just a difarant sort of fuse? nice one for the info anyways..is it an ok amp,and is this the same hill as from the 80s or is hill audio new cos i found this website http://www.hill-audio.com/?page_id=14
jbl_man
Moderator Group Joined: 12 January 2005 Location: London. Status: Offline Points: 11154 |
I dont think these were the most reliable amps ever built,funnily enough,there is a couple on ebay now,and again,both broken!
neilpoints
Young Croc Joined: 03 March 2010 Location: Cornwall Status: Offline Points: 976 |
Hi.
T6.3 is a slow-blow fuse, a 6.3 will protect your amp but might blow unnecessarily. Hill made some great amps, including all the Chameleon models, some re-badged Smartlight. They are all class-A with bipolar transistors as far as I know, so they are supposed to run hot! Sound quality is great. Their biggest problem is the build quality and lack of protection - the components move around too easily in transit, fracturing the solder and PCB tracks, the amps fail, go DC and take out your speakers! Worth fixing, I reckon. I'm working on a Hill amp at the moment! |
former Eurovision contestant
audiomik
Old Croc Joined: 06 April 2010 Location: Bath, UK Status: Offline Points: 2962 |
definitely a 70/80's model,
and yes, that design using a transformer to provide the drive current to the output transistors was unreliable but relatively low cost to build.... Edit: fortunately they were/are relatively easy to repair! Mik Edited by audiomik - 01 June 2010 at 8:39pm |
AUDIO HABIT
cheers jbl man,well it seems iv'e done my bit for the 80s by saving it anyways lol.... thanks for the links too
The Garglebard
Registered User Joined: 29 August 2008 Location: Lancashire Status: Offline Points: 362 |
I've got one of these. Has a dodgy volume control, but otherwise works fine. Sounds great.
I really should get it fixed, but not sure if it's financially viable.
markie
Old Croc Joined: 31 October 2005 Location: Sunny Liskeard. Status: Offline Points: 4570 |
Malcolm Hill provided the PA for Live Aid at Wembley (1985???). He also dabbled in a bit of speaker design with his "Power Cubes" a 4 box system using Volt 12" dual concentrics and Volt 15" (maybe 18") subs.
Quite a historic brand.
neilpoints
Garglebard, that would be very easy and cheap to fix, you could do it yourself for sure.
andyamp
Old Croc Joined: 21 July 2007 Location: United Kingdom Status: Offline Points: 2115 |
as well as transformer drive it had tda2030 to drive the fan if i remember correctly.
http://www.matrixamplification.com/ |
The Garglebard
You've never seen my soldering mate Seriously though, one of the volume pots has a fault. I've just wired it up and if i touch the pot i get sound, if i tap the pot then the sound comes and goes intermittently. Any suggestions?
