Hog Scoop, a few questions |
raspix
Joined: 02 December 2009 Location: Paris, France Status: Offline Points: 51 |
Topic: Hog Scoop, a few questionsPosted: 11 February 2010 at 10:15pm |
Hello,
my mates & I are planning on making these HOGs, and we had a few questions on the construction, and on the speaker that'll drive 'em: ![]() There's another plan with the rest of the mesurments, but I wanted to know if anyone had ever build these, and what's to think of it ? Second question, it is said on the plan that a B&C Speakers 18TBX100 would be good, is that info any good ? What do I need to use to cover the inside of the cab, glass wool ? and last, the type of wood is specified on the plan, would another kind do the job (MDF for example) ? and double bracing the whole cab means every piece of wood that'll be put inside it must be screwed through a brace ? That's about it, pleasant evening to you all Edited by raspix - 11 February 2010 at 10:27pm |
king david
Joined: 17 January 2007 Location: italy Status: Offline Points: 906 |
Posted: 12 February 2010 at 9:28am |
yes, many people built these, and there are various threads on the scoop forum, where you will find all the answers
its a very good scoop, and i have 4 of them with 18tbx100. other drivers like pd1850 can give you more spl. but i didnt hear any other hog so i just can comment on mine...
i didnt put insulation in the chamber, and mdf would be good, but hog is quite heavy with birch ply, an mdf one would be even more difficult to move, so put wheels on it!
you have to build the cabinet (every cabinet, not just the hog) with lots of glue and screws, the same is for braces...
jossdude
Joined: 16 September 2009 Location: Newcastle Status: Offline Points: 133 |
Posted: 12 February 2010 at 10:19am |
Double bracing means that there should be two identical braces accross the width of the design, rather than just on in the middle.
A picture says a thousand words, ![]() Makes them look rather pretty with the double bracing to!
raspix
Posted: 12 February 2010 at 3:28pm |
thanks to you two for the quick answer, would you have by the way some pics of the construction of these ?
bless |
nomis
Joined: 07 January 2008 Location: France Status: Offline Points: 538 |
Posted: 12 February 2010 at 3:41pm |
read the hog scoop thread(nice pics by father francis in there),and a more recent rebated build.search 'hog scoop rebate' in the forum.
Autograff
Joined: 22 October 2008 Location: Sheffield , UK. Status: Offline Points: 1135 |
Posted: 12 February 2010 at 3:59pm |
Go for PD1850 or V18-1200 if you want serious low-end grunt .
Liquid_Steel_Sessions
R8 Records |
king david
Posted: 13 February 2010 at 2:34pm |
Tweet
