HP DL380 G6 Smart Start |
shagnasty
Posted: 25 April 2015 at 11:33am |
I don't know if anyone can help, but...I've just bought a little DL380 G6 for home to retire a couple of G5s I am running, does anyone know if there is a SmartStart version that let me deploy SVR2012 to a G6 box?
I only have Gen8 machine with a warranty so my Hp login is not letting me look for SmartStart as G8 has EFI stylee stuff so no S-Start need, if anyone has the latest S-start iso and it supports 2012 could they please throw it on an FTP as am about to put a 2u server through my office window... |
nickyburnell
Being a Dell man I have no idea which version you need, but came across this
http://smartstart.software.informer.com/8.7/ Probably no good as I'm sure you Googled but sometimes the obvious...blah I feel your pain, hate days like that, makes me want to grow food or something real. |
el_dj
Registered User Joined: 30 November 2007 Location: Denmark Status: Offline Points: 176 |
http://h20195.www2.hp.com/v2/GetPDF.aspx%2F4AA4-7658ENW.pdf
server 2012 is supported but not via smart start... you have to download the drivers and supply during installation. http://h20564.www2.hp.com/hpsc/swd/public/readIndex?sp4ts.oid=3884083&swLangOid=8&swEnvOid=4168 |
Old twat, with an interest in light & sound
shagnasty
Thanks, that was pretty much what I ended up doing, much as I swear by HP Proliant, their support of legacy hardware is a bit random, the tag number bought up no 2012 drivers but I ran the firmware/software maintance pack which made short work of the rest...
shagnasty
I hear that, tnx
slaz
Hoping the OP won't mind the thread-hijack-ette, as it seems to have resolved ....
Got a mini-tower HP baby server here .... ML110 G4. Not being used - and OK - I guess the skip is now beckoning .... but _maybe_ someone could use it. Its a single socket dual-core Xeon @ 1.83GHz if I remember rightly. I put 2GB of ECC non-reg memory into it .... passed all the HP diagnostics - has a fairly "proper" RAID controller (Adaptec I think). Well - its a proper server motherboard - and should still do a job of work for a (very) small office, or for someone learning server admin mebbe. Not after any money (but would need a little drinking money for the memory I bought for it). Don't all rush at once now :-) |
shagnasty
It's not really a crapper, the ML series let you mount standard drives (no £30 hotswap caddy required) will run 64Bit, a dual core 1.8 won't need a 16A supply, ideal for slamming Linux or W7 Ultimate on as a media server/Nas box in a house....
slaz
Careful with the positive comments now mate .... you'll be causing a stampede to my house :-)
But yeah - if I had a labouriously collected set of movies/music to stream through the house - and was choosing between a "high-street" NAS box and somehting like the HP box - I know what I'd choose ... (although you have to justify the extra leccy consumption). |
shagnasty
The HP will use loads more as your data will be there a lot longer!
