  New Posts New Posts RSS Feed - HP4D vertical fogger - how to prime.
BJtheDJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BJtheDJ Quote  Post ReplyReply Direct Link To This Post Topic: HP4D vertical fogger - how to prime.
    Posted: 22 June 2017 at 9:35pm
I've had an Acme (ProLight) HP4D vertical fogger for a long while and recently decided to switch from normal fog to C02-type quick-dispersal, so that I could use it as a 'statement' effect and just run a haze machine in the background to emphasise my beam effects.
I must have had a case of complete brain fade because I ran the machine dry before putting the new fluid in, and now I have the problem in that nothing happens when I use the machine.
I'm assuming that there has to be a certain amount of fluid in the motor to create a vacuum to suck he fluid from the reservoir bottle, but have no idea how to prime the motor - I'm pretty certain that I didn't have to do it when I got the machine (maybe it came already primed).
Helpful suggestions welcomed.
Edited by BJtheDJ - 22 June 2017 at 9:36pm
It's a difficult choice, would you rather have:
A: A vegan son.
B: An OnlyFans daughter
bruce@bluff View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bruce@bluff Quote  Post ReplyReply Direct Link To This Post Posted: 26 June 2017 at 8:00am
Check if the pump motor is still running if not you have either burnt out the coil or the diode. Running the pump dry destroys them in most cases
Post Options Post Options   Thanks (0) Thanks(0)   Quote BJtheDJ Quote  Post ReplyReply Direct Link To This Post Posted: 26 June 2017 at 8:43am
Thanx Bruce, I'll check to see what the state of play under the cover is.
A: A vegan son.
This page was generated in 0.297 seconds.
