Identify these please |
SamV
Old Croc Joined: 21 October 2008 Location: London Status: Offline Points: 8711 |
Posted: 06 June 2017 at 2:48am |
Not strictly audio related but install related.
Can anyone identify the switches here, I need to replace them and they seem modular but not had a chance to undo them yet. Cheers. Also what's this connector called? I've seem them loads of times on daisy chained desk power blocks. |
dylan-penguinmedia
Old Croc Joined: 14 April 2011 Location: Brighton Status: Offline Points: 4575 |
Old MK grid, pre facelift.
spongebob
Young Croc Joined: 20 October 2010 Status: Offline Points: 1395 |
spongebob
Also whomever put the switches in that order needs a slap
Teunos
The connector is a wieland one. Typically used for dimmerpack patchfields here in the NL, or indeed for cabling offices.
Best regards,
Teun. |
shagnasty
SamV
Cheers chaps, and agreed on hall fronts but it was before my time.
njw
The sparky probably wanted to finish up and get to the pub, it was quicker to stick the labels on like that rather than swap a couple of lives over. I've never done anything like that.......
kedwardsleisure
Old Croc Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 4949 |
probably be able to get the gridswitch inners from a demolition site, they were one of the most common grid switch systems. The earlier curved rocker type in white or brown will also fit the later frames. The modern 'gridswitch+' won't as the rockers are wider as Dylan has said already.
North Staffordshire |
