important: seal gasket |
Page 12> |
Contour
Topic: important: seal gasketPosted: 26 May 2006 at 8:33am |
Hello, The gasket on the Ciare 12.00SW is made out of 4 pieces. As you can see on the next pictures there may be small gaps between these pieces: http://img122.imageshack.us/img122/1114/ciarekier2iu.jpg It is important to seal these gaps. They can produce unwanted noises and reduce output (a very small amount but still). Best regards, Walt |
Lyndon A
Joined: 15 November 2004 Location: Bristol Status: Offline Points: 530 |
Posted: 26 May 2006 at 9:44am |
Yep, we noticed on some of ours the gap can be upto 2mm. It doesn't squash that much either when you bolt it down. Hot Glue gun works well.
Laurence G
Joined: 17 May 2006 Location: United Kingdom Status: Offline Points: 145 |
Posted: 17 July 2006 at 12:15pm |
I've no idea if they have changed the gasket material, but although my gasket was in four pieces the gaps where very small, and the gasket compressed down to around 2/3mm.
Jay Lawless
Joined: 22 August 2005 Location: United States Status: Offline Points: 1702 |
Posted: 05 September 2006 at 3:59pm |
i would imagen when the gasket is compressed when mounted then the gaps wouldn't be a problem anymore...
Background: Automotive, Live and Home Custom Design. mid/high level based design and feild experience. Bass specialist |
IAIN RENDLE
Joined: 23 May 2005 Location: United Kingdom Status: Offline Points: 836 |
Posted: 29 October 2006 at 10:43am |
the latest batch of ciare drivers have no gaps in the gasget.
-=vortex sound systems=-
www.vortexsound.co.uk |
SAFETY SAM
Joined: 22 January 2007 Status: Offline Points: 106 |
Posted: 24 January 2007 at 8:44am |
Newest batch................ Where can i get some.............i really really need 4 asap
Charles_V
Joined: 30 December 2005 Location: United Kingdom Status: Offline Points: 357 |
Posted: 24 January 2007 at 12:10pm |
are you in the uk?
Unknown Enemy
Joined: 03 October 2007 Location: Kent Status: Offline Points: 266 |
Posted: 07 October 2007 at 9:10pm |
i have a question about these speakers. what is the rms of these speakers. on there website is just says 1000 watts. is that peak or rms
cheers
toastyghost
Joined: 09 January 2007 Location: Manchester Status: Offline Points: 5867 |
Posted: 07 October 2007 at 11:26pm |
1000w RMS. |
tweeter box
Joined: 21 October 2007 Location: United Kingdom Status: Offline Points: 6776 |
Posted: 11 February 2008 at 3:31pm |
1000w rms!!!! really??? It looks like one of them cheap car audio drivers, no offence
Would these drivers be good for any other design boxes?
Kick bins perhaps?
toastyghost
Posted: 11 February 2008 at 4:52pm |
It's a very tight, stiff and thick cone with a lot of xmax. So from the little I know, very suited to horns, perhaps a tapped one?
roborg
Joined: 05 July 2004 Location: United Kingdom Status: Offline Points: 1026 |
Posted: 08 March 2008 at 12:07pm |
The current batch have slight gaps in the foam gasket, but once the driver is tightened down to the baffle the outer rim seals adequately. Maybe very slight gaps are desirable to allow the speaker box pressure to equalise? (but obviously not several mm ones) Unless you're going to play in an aircraft & drop 10,000 feet a minute
Its a 1K AES, so (assuming Ciare arent being too liberal) 1K RMS too. The venting is pretty impressive on these & it has a sturdy looking 4" VC. As for kick bin, i reckon they could be used, but the heavy cone results in a mass roll-off of ~220Hz so not so high. The power handling is good, but the xmax would never be used in a horn-loaded kick bin, so not the ideal driver. Small bass-reflex kick bin might work quite well
cheers,
Rob.
Page 12> |
Tweet
