  New Posts New Posts RSS Feed - important: seal gasket
Contour View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Contour Quote  Post ReplyReply Direct Link To This Post Topic: important: seal gasket
    Posted: 26 May 2006 at 8:33am
Hello,
The gasket on the Ciare 12.00SW is made out of 4 pieces. As you can see on the next pictures there may be small gaps between these pieces:
http://img122.imageshack.us/img122/1114/ciarekier2iu.jpg
It is important to seal these gaps. They can produce unwanted noises and reduce output (a very small amount but still).
Best regards,
Walt
Lyndon A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lyndon A Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2006 at 9:44am
Yep, we noticed on some of ours the gap can be upto 2mm.  It doesn't squash that much either when you bolt it down.  Hot Glue gun works well.
Laurence G View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Laurence G Quote  Post ReplyReply Direct Link To This Post Posted: 17 July 2006 at 12:15pm
I've no idea if they have changed the gasket material, but although my gasket was in four pieces the gaps where very small, and the gasket compressed down to around 2/3mm.
Jay Lawless View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jay Lawless Quote  Post ReplyReply Direct Link To This Post Posted: 05 September 2006 at 3:59pm
i would imagen when the gasket is compressed when mounted then the gaps wouldn't be a problem anymore...
Background: Automotive, Live and Home Custom Design. mid/high level based design and feild experience. Bass specialist
IAIN RENDLE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IAIN RENDLE Quote  Post ReplyReply Direct Link To This Post Posted: 29 October 2006 at 10:43am
the latest batch of ciare drivers have no gaps in the gasget.
-=vortex sound systems=-
www.vortexsound.co.uk
SAFETY SAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SAFETY SAM Quote  Post ReplyReply Direct Link To This Post Posted: 24 January 2007 at 8:44am
Newest batch................ Where can i get some.............i really really need 4 asap
Charles_V View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charles_V Quote  Post ReplyReply Direct Link To This Post Posted: 24 January 2007 at 12:10pm
are you in the uk?
Unknown Enemy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unknown Enemy Quote  Post ReplyReply Direct Link To This Post Posted: 07 October 2007 at 9:10pm
i have a question about these speakers. what is the rms of these speakers. on there website is just says 1000 watts. is that peak or rms
cheers
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 07 October 2007 at 11:26pm
cheers
1000w RMS.
tweeter box View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tweeter box Quote  Post ReplyReply Direct Link To This Post Posted: 11 February 2008 at 3:31pm
1000w rms!!!! really??? It looks like one of them cheap car audio drivers, no offence
Would these drivers be good for any other design boxes?
Kick bins perhaps?
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 11 February 2008 at 4:52pm
It's a very tight, stiff and thick cone with a lot of xmax. So from the little I know, very suited to horns, perhaps a tapped one?
roborg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roborg Quote  Post ReplyReply Direct Link To This Post Posted: 08 March 2008 at 12:07pm
The current batch have slight gaps in the foam gasket, but once the driver is tightened down to the baffle the outer rim seals adequately.  Maybe very slight gaps are desirable to allow the speaker box pressure to equalise? (but obviously not several mm ones)  Unless you're going to play in an aircraft & drop 10,000 feet a minuteWink
Kick bins perhaps?
Its a 1K AES, so (assuming Ciare arent being too liberal) 1K RMS too.  The venting is pretty impressive on these & it has a sturdy looking 4" VC.  As for kick bin, i reckon they could be used, but the heavy cone results in a mass roll-off of ~220Hz so not so high.  The power handling is good, but the xmax would never be used in a horn-loaded kick bin, so not the ideal driver.  Small bass-reflex kick bin might work quite well Smile
cheers,
  Rob.
web department
