  New Posts New Posts RSS Feed - Increasing size from M6 to M8 T nuts
dnbpc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dnbpc Quote  Post ReplyReply Direct Link To This Post Topic: Increasing size from M6 to M8 T nuts
    Posted: 07 September 2012 at 5:43pm
I've recently had some Hogs built but they have been t-nutted to fit M6 bolts. My PD1851s arrived today and they require M8 bolts, what is the best way to increase the size of the hole so I'm able to mount the drivers?
spongebob View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote spongebob Quote  Post ReplyReply Direct Link To This Post Posted: 07 September 2012 at 5:49pm
Should be a peice of "pee" to sort with a hog, no?
Take the old driver out, remove existing tnuts, redrill with 8mm bit, offer up the new 8mm tnuts and then clamp them into the wood (G Clamp or such)
Edited by spongebob - 07 September 2012 at 5:50pm
JR.junior View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR.junior Quote  Post ReplyReply Direct Link To This Post Posted: 07 September 2012 at 5:58pm
+1000
Post Options Post Options   Thanks (0) Thanks(0)   Quote dnbpc Quote  Post ReplyReply Direct Link To This Post Posted: 07 September 2012 at 6:00pm
Cheers thought it'd be a simple job just wanted to make sure.
jacethebase View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jacethebase Quote  Post ReplyReply Direct Link To This Post Posted: 07 September 2012 at 7:23pm
Just make sure that the new tee is seated properly.
infrasound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote infrasound Quote  Post ReplyReply Direct Link To This Post Posted: 07 September 2012 at 7:45pm
This! you don't want the last tee to fall out Ouch
Run around them all first with a washer instead of the basket, with an electric drill you can get them to bite fully in no time Smile
grazzeee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grazzeee Quote  Post ReplyReply Direct Link To This Post Posted: 07 September 2012 at 7:54pm
i literally just finished the exact same job.
did 4 hogs, last hog top t-nut i think has poped out, its not gripping!
so pissed off. left it to change on a rainy day my screw driver ran out of battery!! lol
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 08 September 2012 at 3:24am
think you need a 10mm drill bit for m8 tee nuts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dnbpc Quote  Post ReplyReply Direct Link To This Post Posted: 29 September 2012 at 1:06pm
Just got round to doing this today and the m6 t nuts aren't moving when trying to get them out, whats the best to remove t nuts? Or will i be fine mounting the PDs with m6 bolts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote infrasound Quote  Post ReplyReply Direct Link To This Post Posted: 29 September 2012 at 1:09pm
Put a bolt in them, and batter it with a hammer.
JohnnyPyro View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnnyPyro Quote  Post ReplyReply Direct Link To This Post Posted: 29 September 2012 at 1:32pm
and when you seat the new T' nuts use a big packing washer on the bolt head side, otherwise you could risk damaging the baffle with countersunk holes
Edited by JohnnyPyro - 29 September 2012 at 1:33pm
Powered by MC2 & XTA
shagnasty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shagnasty Quote  Post ReplyReply Direct Link To This Post Posted: 29 September 2012 at 6:51pm
Yeah, I use a bit of 15mm ply with an off cut of 3x40mm metal bar on it a dn a 1/2" impact wrench to seat tee-nuts, I have few few fail out!!
I'd always put grease or copper slip on the bolts as i fit the driver, spinning Tee nuts are a a pain!!Smile
