invertor question |
phildat
Young Croc Joined: 29 January 2009 Location: manchester Status: Offline Points: 1115 |
Posted: 14 April 2011 at 4:14pm |
We are about to Move to somewhere which Is off the grid and gets power VIA solar and wind.I own two invertors one at 110 and one at 240.As I own equipment that can be run at 110....ie decks and mixer...does it make any sense to use them at 110volts...will this be any less demanding on the batteries?
Its just a ride.
Saturnus
Old Croc Joined: 13 July 2010 Location: Copenhagen Status: Offline Points: 2025 |
Quite the opposite actually. The inverter (dc-ac conversion) efficiency would be roughly the same but the reverse is not the same. It's more efficient to ac-dc convert (as happens in all power supplies) from 230V AC than from 110V AC. Total efficiency increase is between 5% and 10%. Edited by Saturnus - 14 April 2011 at 4:24pm |
slaz
Are these cheapy inverters ? If so, you may get problems with turntables if they AC motors (e.g. most types of belt or idler drive) as the inverter o/p is gonna be pretty much square wave.
I'd say to run these types of gear you'd need pure sine wave inverters (a good deal more expensive). But thats an educated guess - not based on experience. |
phildat
No not cheap at all..both pure sine wave from when we lived on a boat..
Its just a ride.
CCAV
Registered User Joined: 25 October 2010 Location: North Carolina Status: Offline Points: 181 |
Check E bay for APC Smart ups used and without batteries (Shipping weight ) It's a pure sine wave inverter They come in many different capacities if you look hard you can find them for $50 I have one in my workshop with 4 -12v car batteries as part of a solar experiment and I'm running my shop on this setup
In my early years my favorite phrase was "If it's too loud your too old" Now I'm just too old
