  New Posts New Posts RSS Feed - Jah Tubbys amps
Jah Tubbys amps
Tom Umney View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom Umney Quote  Post ReplyReply Direct Link To This Post Posted: 20 September 2006 at 7:51am
A mate of mine who runs a massive system use to run it with 2 racks of Infinate Amps, then the other day he used a stack of JTS amps & says they sound better.
But who knows, I'd personally have to hear that for myself.
I was in Brixton Rec once when the sound systems were setting up, & Iration Steppas was testing 2 separate 5k amp made by the Late Linx from B'ham & he was not happy with them at all.
They were using each one on bass per stack (3 stacks in all) & the 3rd stack had a JTS 10K amp (5K per side) where he was using one half, & you could easily hear the JTS out perform the Link amps.
When I hear the system with the JTS & the Infinates together my own verdict will be updated.
Which series of JTS amps are you talking about here outperforming the Void Infinites?
The JTS Proamp series or the UA series or the Annhiliator series?
Tekasis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tekasis Quote  Post ReplyReply Direct Link To This Post Posted: 20 September 2006 at 9:17am
The amps I'm talking about which my mate rated over the Voids were the UA Series...
The amp which sounded better than the Link ones was the Annihilator.
UA6 Amplifier 6000Watts-3U Rackmount
  UA6 Specifications
2 Ohms = 3000 Watts Per Channel
4 Ohms = 2250 Watts Per Channel
8 Ohms = 1450 Watts Per Channel
UA4 Amplifier 4400Watts-3U Rackmount
UA4 Specifications
2 Ohms = 2200 Watts Per Channel
4 Ohms = 1700 Watts Per Channel
8 Ohms = 1100 Watts Per Channel
UA3 Amplifier 3200Watts-2U Rackmount
UA3 Specifications
2 Ohms = 1600 Watts Per Channel
4 Ohms = 1250 Watts Per Channel
8 Ohms = 800   Watts Per Channel
ANNIHILATOR - MegaAmps
SAMIAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SAMIAM Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2006 at 12:59pm
Originally posted by Static Age Static Age wrote:
i was kind of expecting it to be a bit cheaper than that. thats more expensive than a Infinate 8.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SAMIAM Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2006 at 1:04pm
Try UA4 just under a grand and nuff power to drive 4 box easy.
I got 6!
jethrocker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jethrocker Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2006 at 1:17pm
What you running off your six (SIX!) UA4s Samiam? Thats a serious Bass section you have if you're powering 4 bins of each amp..you running 24 bins?
Assuming you're running four of each piece (and assuming the stated specs are realistic) , thats two a channel-1700w at 4ohms. 850Watts per box. Plenty power for some boxes, but anyone running 1850's might find they're not getting enough juice. Even with less power hungry cones like voids I'd want more headroom I think.
smithers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smithers Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2006 at 6:28pm
damn i've been drooling over the blue mega amp for years......same deal really....emailed them but no reply.
any idea how much it costs?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom Umney Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2006 at 11:26pm
http://www.disciplesbslbm.co.uk/siren.html   All e-mail info is there.
Hes an agent for Jah Tubbys gear and sales.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tekasis Quote  Post ReplyReply Direct Link To This Post Posted: 07 March 2007 at 7:00pm
Anyonw know if these amps comes with a warranty/guarantee ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tekasis Quote  Post ReplyReply Direct Link To This Post Posted: 10 March 2007 at 11:49am
I didn't realize till the other day that the JTS UA4000, besides been a slightly older model, is much different from the UA4. But apparenty still dangerous.
mykey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 10 March 2007 at 9:36pm
as in...you can get a shock from it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tekasis Quote  Post ReplyReply Direct Link To This Post Posted: 11 March 2007 at 3:52pm
You got me there...Dangerous as in powerfull & stable down to 2ohms.
Venny14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Venny14 Quote  Post ReplyReply Direct Link To This Post Posted: 03 March 2014 at 1:27am
How much would people say an old well used slightly tatty JTS UA4000 is worth this day n age?
Because thats how I like to do things, Thats why.
