JBL TCBs... value and thoughts... |
Post Reply | Page 123 4> |
charlysays
Registered User Joined: 16 June 2015 Location: Wales Status: Offline Points: 413 |
Posted: 25 June 2015 at 5:21pm |
I've come across a couple of these, typically unloaded. Cabs are structurally fine and the front face is good and original. The rest of them are well scuffed.
No drivers, not even any baskets. Stupidly I forgot to take note of which one they were, but at 1.5m tall on end they are going to atleast be the dual 15" or dual 18". The seller said she wanted £100 each for them which seems steep to me... I was thinking max £100 the pair seeing as it could cost hundreds to load them. Is there a stronger driver with similar parameters which could be used in place of the old JBL driver? Once loaded do they have a respectable sound pressure level in the 25-40hz range? I've heard they go low but have little definition, no kick just rumbles. That sounds ok to me as I already have 6 x 18" reflex bins. I suppose Id need to heavily utilise the time delay feature on my DCX... I don't know why I like the idea of them so much... probably because it says SoundPower on the back of them! |
shaun1264
Registered User Joined: 06 September 2013 Location: Surrey Status: Offline Points: 292 |
Originally loaded with 15" 2225 or 18" 2240
The TCB probably from the sound power series. 4788 or 4785 I have a pair of the 4785's with orginal drivers. They do sound good. Very deep low. Edited by shaun1264 - 25 June 2015 at 6:05pm |
charlysays
Cool, sounds like a speaker worth having. What do you reckon to the value of empty cabs? Front face is decent condition, rest is scuffed back to the wood on all the corners but no missing laminates as far as I could see... metal input plate is in good condition for the age...
Greg32
Registered User Joined: 14 December 2004 Location: Australia Status: Offline Points: 116 |
I have no personal experience with them but have read a lot about them, they apparently sound lovely but are easily overdriven. there was a thread here somewhere that was a few pages long about the jbl tcb and there merits.
APC321
Young Croc Joined: 24 August 2013 Location: West Midlands Status: Offline Points: 684 |
I used to use a pair of the 2 x 18'" 4788 in a fixed install in a venue.
They went down low, but did not seem to be particularly efficient. I had no problems with driver reliability. They were very heavy and bulky and I would not recommend them for mobile use. |
shaun1264
They all have flat response.
http://www.jblproservice.com/pdf/Sound%20Power%204700%20Series/4785A.pdf http://www.jblproservice.com/pdf/Sound%20Power%204700%20Series/4788A.pdf The Sound Power Series were similar to the older JBL 4688 model. Just different tunings and slightly different box dimensions. 101dB SPL for 1 watt. Back then efficient for the 4788 version. Same here, no problems with reliably. I have a 28Hz 48dB Butterworth low cut on my 4785's. Driven by a Crown Micro-Tech 1200 or a Crown K2. I think a lot of them were just clipped to the max/overdriven hence a few turn up for sale with no drivers. I'd say £100 is a decent price if the grills and metal bars inside are intact My pair just sit around now. One is used for a home system. |
charlysays
I've got them now... Two Soundpower 4785. No drivers whatsoever... Everything else there though it seems. One cab appears to have suffered some water damage to the ply in one area and has lost the outer veneer. Probably won't affect it but I might use my boat repair skills on it with some epoxy and a veneer.
What drivers am I looking for for these? Jbl 2225 or 2226? Kinda wish they'd been the dual 18s, to be fair they are heavy enough already! Anyone got tips on how to fit a speakon nicely into the backplate? It has weird multi pin sockets atm... Cheers |
charlysays
colint
Old Croc Joined: 06 October 2007 Location: United Kingdom Status: Offline Points: 5227 |
Lovely boxes load them with 2226h which JBL say is a replacement for the 2225 just don't overdrive the cabs, most of the problems with these cabs are caused by people thrashing the arse out of them treat em nice they'l last for ages.
shaun1264
As above. 2226's. If you tried a different brand with similar specs to the 2226's you will need the drivers to be shallow else they won't fit and you will end up having to get some spacers.
Btw, those boxes you have got are the early versions which I believe had removable fronts. |
charlysays
Yo, yes the fronts are removable... Lots of crosshead screws. The cloth covered grills I guess fill in for the lack of grills on tje ports. Doesn't look like it ever had grills in the ports.
I'll start looking out for some 2226s. I take it go for 2226h unless reconing, in which case could get 2226g basket and recone to 8ohms. Will see if I can sympathetically adapt the terminal plate for speakon. So do these 4785s go deeper than your typical single 18 reflex? Has anyone run these with reflex cabs? Guess you'd need to use a fair bit of time delay on the reflex cabs and make sure the drivers in the TCB'S are wired correctly |
jbl_man
No value at all as an empty cabinet Charly,it's just whatever you feel happy paying for them...if they were loaded,you buy them purely for the value of the drivers inside. Not one of JBL's better designs if im honest. |
