  New Posts New Posts RSS Feed - JL Audio HX series...
DJ-Dulux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DJ-Dulux Quote  Post ReplyReply Direct Link To This Post Topic: JL Audio HX series...
    Posted: 19 June 2016 at 8:25am
Anyone tried the jl audio amps, mainly the HX series 1x160w and 4x50w at 4 ohm. Power output quoted at 12.5v supply and 2 ohm stable for a bit more power?
IP6# rated so ideal for boombox and resonable crossovers built in.
Looking at the hx300 to run 2 Cubo 12 and maybe 4 when i build more.....
Thanks,
Dupe...
Dupe...
Ganon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ganon Quote  Post ReplyReply Direct Link To This Post Posted: 20 June 2016 at 6:25am
You get more power out of the Pioneer GM-D8604 and it dosn't cost alot more.
If you want to go smaller, the Bassface 4.2 should do i realy good job and cost about half of the hx.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DJ-Dulux Quote  Post ReplyReply Direct Link To This Post Posted: 20 June 2016 at 6:50am
Thanks ganon, anyone know what power the pioneer does at12.#v, all the specs are at 14.4v i guess.....
Dupe...
Edited by DJ-Dulux - 20 June 2016 at 6:52am
Dupe...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ganon Quote  Post ReplyReply Direct Link To This Post Posted: 20 June 2016 at 2:10pm
What ive heard, it's about 4A at a 2.1 setup. :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote DJ-Dulux Quote  Post ReplyReply Direct Link To This Post Posted: 20 June 2016 at 3:20pm
Sorry, I meant output power?
Dupe...
Dupe...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ganon Quote  Post ReplyReply Direct Link To This Post Posted: 20 June 2016 at 5:00pm
ohh, don't know the output at 12v.
But i can say it can play loud at 12v, used it on two Cubo 15 and EV sx200, and now it's powering the sx's and a cubo kick.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DJ-Dulux Quote  Post ReplyReply Direct Link To This Post Posted: 04 April 2017 at 12:57pm
Well I picked up a MX300 / 1 (HX seems to be no longer available), nominally 300W at 2ohm. Interesting feature is that its IPX6 rated so ideal for boombox use.
But at 12.5V should do, 1 * 250W at 2 ohm, 1 * 160W at 4 ohm so 80W to each of my Cubo12s.
I have only measured quiescent current so far, 0.69A at 12.8V and less than 0.1A in standby.
I has subsonic and LP filters and remote volume so should be able to integrate it into the rest of my system without too many headaches.
Will publish further info when I measure it....
Dupe...
Dupe...
