JRX |
The Builder
Old Croc Joined: 03 January 2010 Status: Offline Points: 3107 |
Posted: 06 September 2014 at 5:01pm |
Acquired a pair of JBL JRX115 for little money (100) but could not put up with top end.
Beyma CD10fe installed with an adapter and they are very sweet. |
It just is.
odc04r
Yeah, the stock ones are pony. Replaced a pair with selenium tweeters years ago. Much improved.
djeddie
I changed mine for the JBL 2416 that's in the M350 cabs, as I had a pair on the shelf.
Mind you, while I was at it I swapped the LF for an Eminence Delta LF. A much better sounding cab! I've used them for pub gigs, both with and without subs, and they do deliver. |
patryk1305
Registered User Joined: 13 December 2012 Location: United Kingdom Status: Offline Points: 488 |
I liked my JRX 125 apart from the top end of course, the only other downside was the mdf enclosure... The joints decided to fail...
The Builder
I only use them 70 up on top of 18 reflex, so should be fine.
Must admit though, with the aggressive PAudio pricing I was thinking of a bass driver upgrade Edited by The Builder - 07 September 2014 at 10:34am |
It just is.
patryk1305
Tbh I always thought the woofers were pretty decent in them
The Builder
Must try them full range.
It just is.
SamV
Old Croc Joined: 21 October 2008 Location: London Status: Offline Points: 8711 |
I've upgraded ours with CP350Ti HF and the lower bass unit is now P Audios E500s or something. Sounds MUCH better.
I only stumbled on the P Audios as a last resort as I needed to replace a driver last minute before a gig and getting the JBL driver was proving tough and Blue Aran suggested the P Audios which turnt out to be an upgrade. Though it made the cabs even heavier lol. |
shaun1264
Registered User Joined: 06 September 2013 Location: Surrey Status: Offline Points: 292 |
The JRX has the M115a 15" driver. Its very near the same driver as the ones found in the old TR series, (just upgraded power rating) a good trusted driver. I too think it's a good driver.
The Thiele Small Parameters can be found in this link: Edited by shaun1264 - 09 September 2014 at 10:40am |
The Builder
Thank you, nice link
It just is.
