  New Posts New Posts RSS Feed - Just finished X1
Just finished X1
Message Reverse Sort Order
Dj Maca Roots View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dj Maca Roots Quote  Post ReplyReply Direct Link To This Post Topic: Just finished X1
    Posted: 22 November 2009 at 4:01am
Thats a cool tip, thanks.
Can't Stop Jah Music
chrisw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisw Quote  Post ReplyReply Direct Link To This Post Posted: 14 September 2009 at 10:42pm
Hi i am a furniture maker, here is a tip that will slove the washing powder problem!!
I like the idea of eliminating screws on the outside of the cab,  shape 50X50mm pine battens in a slight curve. cramp either side across the final side to be glued, this will evenly distribute presure when cramped on the far edges. on the x1 cab, i would use 4 battens with 8 sash cramps. hope i have explained this well!! chris
leswoodies View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote leswoodies Quote  Post ReplyReply Direct Link To This Post Posted: 30 August 2009 at 1:11pm
X1 bin still doing it's job greatly without any complain...
Thanks for the comments by the way.
Respects,
Ryan94 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan94 Quote  Post ReplyReply Direct Link To This Post Posted: 08 August 2009 at 1:35am
lovely build mate!
Dont just Hear it, FEEl IT!!
wooof View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wooof Quote  Post ReplyReply Direct Link To This Post Posted: 05 August 2009 at 10:44pm
          beauty build Bud ! may i suggest fluted dowels if it hasen't already been?
roundsoundz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roundsoundz Quote  Post ReplyReply Direct Link To This Post Posted: 29 June 2009 at 11:23pm
Nice job on them. Have you tested them out yet, Im thinking of building a couple of these to go under our HD's, have you used any padding/wadding in it at all? or do you not need to?
TechnoChef View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TechnoChef Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2009 at 6:39pm
It's not Marquetry you're thinking of is it?
justamadman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote justamadman Quote  Post ReplyReply Direct Link To This Post Posted: 28 February 2008 at 4:46pm
mark mate,,,, scorching maybe???
in front of the bass bins baby
Post Options Post Options   Thanks (0) Thanks(0)   Quote leswoodies Quote  Post ReplyReply Direct Link To This Post Posted: 27 February 2008 at 9:27am
Hey people,
Maybe I can use this topic to ask you the dilemma we have to face now that the X1 is ready for use.
What will be on top of it?
Cutting the X1 were it should be done, around 80-90Hz, we would like to go for a single 15" producing the frenquencies from there to 200-300Hz maybe.
To be honest, money limitations will force us to use our two Peavey PRO-12 for the mid range.
Any idea of what could be built in this type of situation?
Every advice/suggestion is welcomed.
Thank you,
Leswoodies
Post Options Post Options   Thanks (0) Thanks(0)   Quote leswoodies Quote  Post ReplyReply Direct Link To This Post Posted: 25 February 2008 at 9:11am
Thanks guys for the positive feedbacks!
Yes, the idea for that access panel was to make the angles round what makes quite a difference in the aspect. Sadly, the speakon connectic hole is not perfectly round, but I won't upload the pic Wink
All the best
djstefanos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djstefanos Quote  Post ReplyReply Direct Link To This Post Posted: 25 February 2008 at 5:01am
access panel +1Thumbs%20Up
GIVEorTAKE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GIVEorTAKE Quote  Post ReplyReply Direct Link To This Post Posted: 23 February 2008 at 12:33am
Originally posted by leswoodies leswoodies wrote:
We are thinking of drawing something on the outter side of the box, maybe also with fire, but this time with something more substantial than a soldering iron! To cover it we would use a see-trought glaze, maybe a little darker than the wood itself.
Search  Pyrography pen, that should make it easier.
It's quite fun too, I remember doing some at school...I wonder if it was a safe activity for kids high on sugar though....
very nice work on your boxesClap
Edited by GIVEorTAKE - 23 February 2008 at 12:41am
Forum Software by Web Wiz Forums® version 10.10
This page was generated in 0.328 seconds.
