Just starting out, advice appreciated. |
Post Reply | Page 12> |
vurso
Registered User Joined: 05 June 2014 Location: Plymouth+Crnwal Status: Offline Points: 20 |
Posted: 27 October 2014 at 8:19pm |
Me and a couple of friends have started building a soundsystem & have got this far without spending a ridiculous amount of money, and are happy with the stack as it stands.. We need to think about getting amps, a crossover, equalizer.. What gear would people recommend? Looking at a behringer ultradrive and maybe powering the subs and kicks with an Infi 8 Mk1, Also, what would people suggest for crossover points? We are running the SBH's with 18LW2400 drivers, the BS1200 are loaded with PD154's. We took the Kicks out this weekend just gone, they sound absolutely insane. The tops are Turbosound THL-2's, one with original driver, one with a PD 15" cone, the original driver needs a recone which we will get sorted soon. Some general advice appreciated. Edited by vurso - 27 October 2014 at 8:57pm |
cookie-dj
That's an amazing first time stack! I thing would always recommend is to have the same drivers in the same speakers.
Ultradrives are good for the money. (if you buy new - some old models are dodgy) Try and look for the Inf8 MK2 if you can ( or MK1 with MK2 upgrades if they are done by a reputable person) |
You can't polish a turd!
THECANDLEMAN
Young Croc Joined: 08 December 2008 Location: CentralScotland Status: Offline Points: 1144 |
id use 2 separate amps to run your bass.
One for kick and one for sub if you do it the other way you'd be running half your amp at 2ohms and the other at 4ohms which isnt the greatest for performance and lifespan maybe an inf8 mk1 on sub (can get them for £6-700) and a used matrix 5000H or xt5000mf on kick That along with an ultradrive And then work out crossover points and delays and your half way.
Motion Systems - Void Airmotion, Airten & Stasys 218 With Powersoft DSP
cookie-dj
if its 2 SBH and 1 bs1200 (which what I though the bs1200 is 4 ohms?) the amp will see an equal load.
Not ideal putting all your eggs in 1 basket though. Could even try inf6 for another option than matrix - if you wanted to keep the amps the same brand that is. |
THECANDLEMAN
photo shows 2 subs and 2 double kick ?
cookie-dj
oh my bad (pics sometimes don't show on my phone!)
Then yes 2 amps for sure. I think there was an inf6 and dbx driverack in a rack on ebay a couple days ago at a decent price but not sure if its still on. There's a few matrix amps floating around on rig re-sale on facebook too (seems like its become a matrix re-sale page recently haha) Edit: forget about the inf6 for 2x double kicks
Edited by cookie-dj - 04 November 2014 at 9:35am |
vurso
Thanks for the positive words, and thanks for the advice. I’ll share a link to this thread with the other guys and we’ll see what’s the best route to take. I'll update when we make more decisions! |
bee
Old Croc Joined: 14 June 2011 Location: Middlesex Status: Offline Points: 4553 |
the mk1 mod / upgrade, does not make them a mk2, internals differ a bit. But the mk1 mod is still worth doing on them.
vurso
could we not run the SBH and A.S.S at 4 ohm on each channel? at least till we gather the money to buy more bass amps.
lgosdset
Young Croc Joined: 28 September 2010 Location: Reading ish Status: Offline Points: 1203 |
yes but you would have to wire the two drivers in the ass in series, which would mean less power per driver, I am sure those cabs are quite efficient tho so will still make a decent amount of racket. |
bass*en*mass
if 2 high power subs is all you "need/could afford for quite a while/suits the rigs purpose etc." i would have gone for 4ohm drivers. 2 in series would have 8ohm impedance, much cheaper and easier to power imo (just bridge an Amp thats about 1.5kw at 4ohm p.CH)
Same goes for double 15s, assuming they are loaded with 8ohm drivers, wiring them in series internally, connect 2 cabs in parallel - again a 8ohm load which might be cheaper to power imo. for example, i have used 2 limmer double 15s a side on a bridged lexon PQM8... roughly 2.5kw a side, and if the Amp should have had a fault with one channel (its not likely both ch. go down imo) i could have still used the amp in normal stereo mode and the show would go on ;) - on a side note, compared same setup with qsc PL380 and pcm18, pl ran out of steam way too quick but sounds nice, pcm had more grunt but less attack - my opinion, quite subjective :) |
vurso
Just an update;
Purchased Berry Ultradrive, 2 x Crest 7001 & 1 x Crest 8001. After an amp rack and other bit but will update again once full rig is in action maybe post some videos too.
