Lab Gruppen 10000Q with PD1850's |
Post Reply | Page 12> |
32true
Registered User Joined: 03 November 2016 Location: Maidenhead Status: Offline Points: 67 |
Posted: 08 November 2016 at 9:56am |
Just wanted to double check before I make the purchase.
I have 2 PD1850's at the moment, looking to expand to 4 quite soon. The FP10000Q runs 1350W @ 8 Ohms. Can I run the 2 drivers from 2 channels initially then run 4 from 4 channels when I need to expand? The PD's are rated at 800W A.E.S but I've heard they can easily handle way more??
hi grade
Young Croc Joined: 18 June 2008 Location: manchester Status: Offline Points: 965 |
Depending on application and enclosure but the 1850 can do lots more with a different choice of amp !
32true
The drivers will be loaded in hog scoops, can you give a recommendation for a more suitable amp?
hi grade
Lab fp 13000 lab fp14000 mc 2 e90 powersoft k10 if your dead stuck on lightweight and play different types on music
If your on a budget play mostly sub heavy music only play out now and again then crest 9001 crest ca18 crown vz 5000 void infinite 8 sae pcm 18 and qsc pl9 jts ua6 lab gruppen copy All spank 1850s |
hi grade
Lab 10000q will do a job and sound nice and clean but you will run out of headroom
Edited by hi grade - 11 November 2016 at 9:53am |
paulus
Old Croc Joined: 14 December 2005 Location: SOUTH BIRMINGHA Status: Offline Points: 3181 |
Depending on application and enclosure but the 1850 can do lots more with a different choice of amp !............massive plus 1..... and different type of box tbh
TRENDSETTER SOUND SYSTEM
luton_soundman
Old Croc Joined: 03 August 2010 Location: Bedfordshire Status: Offline Points: 4539 |
Hogs arent a good scoop. And agree that amp is weak. My friends are getting good results with the SAE. But if you're like me then torroidal power is what you want. Ca18, 9001, VZ5000, vz5002 etc. Just so happens i have some vz5000 & 5002 for sale very soon :)
dylan-penguinmedia
Old Croc Joined: 14 April 2011 Location: Brighton Status: Offline Points: 4575 |
For that application, I'd go for a pair of amps = 2 power supplies to provide the juice, unless you're particularly short of rack space.
32true
Thanks for the advice everyone. Going for hogs because I want the versatility to play reggae but also hard dance music, not as weak as a super scooper but not as destructive as a 1850 horn. 2 amps sounds like a good idea, not sure I can afford to k10 budget is £500-£1500 haha. How many watts should I aim to give each driver then? 1500?
hi grade
For your budget and applications would crown vs5000 sae pcm or pas 14000 lab based amp or void infinite 8
hi grade
£1500 is a load of money this close to Xmas try your luck in wanted section mater of fact bring 1500 to my lock up and you can have a huge choice of my amps
Edited by hi grade - 11 November 2016 at 12:21pm |
matty w
Young Croc Joined: 27 August 2008 Status: Offline Points: 798 |
Have used the real 10,000 q quite a lot, powering 4 twin 18" reflex bins loaded with b&c tbx100 drivers !
I run 3x lab 10,000 q amps for the whole rig and share the bass cabs out between them , so one amp sees two bass cabs and the other two amps see a bass cab each ! The amp that has two bass cabs clips earlier than the other two ! Tells me the power supply hasn't got the minerals for proper sub ! Don't get me wrong still sounds sweet but compared to when I run the same rig off of the big boy 2ch lab 13,000 is it ? On sub , then the 10,000 q's on tops , it clearly doesn't get the 40hz and below happening the same ! Guess you would be fine if your bins high pass at 45hz ... Depends what your running !! My 2c |
Black to black , red to red , blue to bits ....
