  New Posts New Posts RSS Feed: LAB Sub Build
  FAQ FAQ  Forum Search   Chat Chat  Calendar   Register Register  Login Login
LAB Sub Build
 Post Reply Post Reply Page  <1 2345>
Message Reverse Sort Order
Chris P View Drop Down
Online Status: Offline
Post Options Post Options   Quote Chris P Quote  Post ReplyReply Direct Link To This Post Topic: LAB Sub Build
    Posted: 13 March 2008 at 11:27pm
Yeah some, but its been slow. Have been taking my time cutting all the pieces and getting that centre module built. I've got pics of it going up in stages, but i was waiting till a had a significant amount of pics.
Should get a real crack on them on Sunday.
jethrocker View Drop Down
Post Options Post Options   Quote jethrocker Quote  Post ReplyReply Direct Link To This Post Posted: 13 March 2008 at 1:59am
Any progress?
biotec View Drop Down
Post Options Post Options   Quote biotec Quote  Post ReplyReply Direct Link To This Post Posted: 07 March 2008 at 4:06pm
Originally posted by justamadman
f**k that, if you f**k it up do it again don't go trying to bodge it with paper clips  and chewing gum..................... do it right
just out of interest, how much ply would you have to go through to make a pair of labs
If you have a gap of less than a milimetre it is not normally enough to compromise the structural integrity of a cabinet but may well let some air flow if under high pressure. If you can find an instance where polyeurathane glue and gripfill did not provide enough strength or gap filling properties for gaps of this size then let me know.
As every carpenter knows, the glue is stronger than the cabinet; fixing the kind of tolerance issues that are unavoidable with a non homogenous material like wood with glue and adhesive filler is pretty standard in all forms of construction. Obviously if you have large gaps then the strength of the cab is compromised and you'll need to recut the piece, but my original statement said 'if in doubt', there are no doubts in anyones mind when you can see daylight through a gap or can stick your finger through it.
Post Options Post Options   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 07 March 2008 at 3:57pm
5 sheets and plus a tiny bit more.
When i calculated it i made the baffles out of the mdf and all the rest fits in 5 sheets :-)
Total Production
www.totalproduction.com.mk
http://www.facebook.com/home.php?ref=home#!/?ref=home
http://www.myspace.com/totalproductionmk
Mark James View Drop Down
Post Options Post Options   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 07 March 2008 at 3:29pm
its around 2.5 sheets of 8x4 per cab iirc.... maybey a little less.
so 5 sheets per pair?????
rip bpm sound system :(
justamadman View Drop Down
Post Options Post Options   Quote justamadman Quote  Post ReplyReply Direct Link To This Post Posted: 07 March 2008 at 3:23pm
Originally posted by biotec
I think the comprimise that you suggest is perfect, it should last as long as a ply cab and will meet your budget. Good luck with the rest of the build, it's not a particularly complex cab to build, it's just slow because of the number of pieces and needs to be done perfectly to ensure everything is nice and air tight.
If in doubt, get the gripfill and polyeurethane glue out.
Edited by justamadman - 07 March 2008 at 3:24pm
in front of the bass bins baby
Post Options Post Options   Quote Chris P Quote  Post ReplyReply Direct Link To This Post Posted: 07 March 2008 at 3:04pm
Cheers fellas! Right, thats that settled then. Ply sides it is. I'm just working on those funny angled pieces that lead from the heart of the module to the begining of the mouth of the horn. Those angles are proving to be a right mare....
Lasse Lukkari View Drop Down
Post Options Post Options   Quote Lasse Lukkari Quote  Post ReplyReply Direct Link To This Post Posted: 07 March 2008 at 10:37am
At the time I built my first two labsubs 4 years ago there wasn't any mm plans available and I didn't know how to use cad, so i used 19mm mdf for the module just like you. Everything else is 18mm ply.
Edited by Lasse Lukkari - 07 March 2008 at 10:38am
Post Options Post Options   Quote biotec Quote  Post ReplyReply Direct Link To This Post Posted: 07 March 2008 at 10:14am
Post Options Post Options   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 06 March 2008 at 11:24pm
If you combine ply and mdf than just make the big side panels from ply. They are handeling most of the abuse.
MDF is fragile and corners can be easily damaged with all that weight even  by the ligt impact during the transport.
To load tne labsub in the truck you need minimum of two strong man.
Total Production
Bulletin Board Software by Web Wiz Forums® version 9.69
Copyright ©2001-2010 Web Wiz
