Large 12v sound system (more pics added) |
Post Reply | Page 123 6> |
Edd Jordan
Young Croc Joined: 10 January 2008 Location: United Kingdom Status: Offline Points: 1364 |
Posted: 13 May 2013 at 11:43pm |
Been asked to build a system for a band wanting to play at some festivals this year.
system 4x 12" bass bins loaded with sov 12-200s (thanks to Paulie paul) 2x top cabs loaded with 2 celestion kt8-100 driver 2 a side and 1" p audio 440s driven by 1 2x 300watts sure electronics amp 1 4 chaneel 4x 100watt sure amp 2x 300watt power booster mini dsp 2x4 electronic cross over and a sure electronics potentiometer for system input control power from 2x 140ah 12 leisure batteries. they have a welding friend who is going to build a 2 person bike contraption to move it around on (pics to follow) First top cab coming to life. Bass bin on test 112 ltr box crossed from 180hz to 45hz tuned to 48hz sounds great considering the driver, played D & B through it for 6 hours at the week end and it sounded good. plenty of bass & kick and not to boomy. mission hifi speaker filling in for the top cabs not fully ready yet. hope to have the rest of the cabs built by the week end and will have alot more pics up soon and info on the amp boxes and power system. Edited by Edd Jordan - 24 May 2013 at 2:57pm |
Saturnus
Old Croc Joined: 13 July 2010 Location: Copenhagen Status: Offline Points: 2025 |
Looks good. Very good. Remember to test them (bass bin to top level especially) outside on a fairly open field as it's quite surprising how much deep bass is sucked away in free air.
Edd Jordan
Cheers. indeed, thats why i went for 4x 12" cones in bigger than normally boxes they start to dip naturally at 49hz when i did a sweep test. i hope to get it out side for a real world test very soon. i can imagine it should be more than adequate bass wise for the use its intended but hey watch this space. the drivers are pretty efficient and need very little to drive them well.
slaz
Whoo. Thats quite some battery-powered rig there.
Hope those blobs of electronics are gonna prove reliable for you .... this is for live music - yes ? |
Edd Jordan
yes, live singers bass player and ableton. i hope so too! but that said and not wanting to jinx it iv not had a problem yet with a sure amp.
slaz
Thats quite "brave" of you Quite a bit to go wrong with the electronics (thinking of current inrush, DC offsets, ground loops etc.) Think - given that speaker complement - I'd have been inclined to go down the good quality car amp route there .... for (I think) a quiet life (OK then - laziness ) ..... It would likely sacrifice some efficiency for reliability/simplicity ..... but obviously that depends on your run-time agenda. Your speaker setup would seem to lend itself very well to car amps though .... e.g. 1 x good big class D monobloc (something around 600 real watts) for 4 x 12" drivers = 2R load = good. For mid-tops a regular 2ch, or 4ch one bridged into 2 .... assuming your 8" drivers are 8R that'd be 4R cabs - would work well with passive Xover in em (yeah might need "special" Xover for 4R mid + 8R CD). I'd have thought the car amps built-in Xovers would work well - caveat being that the "sub-sonic" filters are usually set too low (like 25-30) .... but I think one or two do let you tweak this. Anyway - it'd be really interesting to compare overall efficiencies of the 2 setups .... |
Edd Jordan
Every thing was on a budget, and going the way i did with these amps was by far the cheapest bangs for buck i could get. i hope it proves to be reliable. ground loops can generally be solved by careful wiring also there will be a half decent transfo on stand by if needed. im sure(hope) it will fine. but luck would have it a friend of mine just gave me a car amp class d so i have a back up if things go wrong now. more pics up end of today.
amlu
Young Croc Joined: 30 November 2009 Location: london Status: Offline Points: 740 |
like your bass drivers... 52 quid on ebay looks bargain.
5.5mm xmax and 100db sensitivity quite interesting. |
Edd Jordan
need a big box but if you can deal with that they go low enough to make some half decent bass.
studio45
Two thumbs up, I'm working on something very similar! See you in a field this summer, I hope :)
PS - Sure have excellent customer service but you just have to persevere a bit to get them to do what they should about boards that break. I wouldn't worry about total system failure, but since they are cheap, it does make sense to buy a spare board in case one gets bored of life in the middle of a job - as a replacement will take 2 weeks to arrive, minimum.
slaz
I'd go along with that .... especially if there's a commercial/professional agenda there. I suspect the car amps (good ones) would be a bit more robust overall .... which might be significant for live music .... some kind of limiter/compressor would be good to have IMHO. |
Saturnus
As I always say: "buy cheap, buy twice". :) |
