laser measurement of distortion |
Post Reply | Page 12> |
70,s hero
Young Croc Joined: 14 December 2014 Location: bristol Status: Offline Points: 637 |
Posted: 04 January 2016 at 8:19pm |
I met a client yesterday who manuafacturers laser measuring equipment, in the conversation the inevitable subject came up. He said that it would be quite simple to design a laser to measure cone movement.
This could be compared to the input signal to ascertain distortion, it could then lead to a corrective digital system to minimise distortion. I know about the accelerometers etc but this seems to be an interesting way to get reliable feedback from equipment. He seemed quite interested and asked about the frequency requirements, I said about 30k as although we only hear to about 16k, it seems fashionable to oversample, it may be that there are high frequency signals in this range that are unwanted within the signal approaching DC in terms of what the load sees. |
Top banana
toastyghost
Pretty sure you've just described the IPAL platform and therefore also part of M Force platform.
King George
Registered User Joined: 18 January 2011 Location: South Status: Offline Points: 334 |
AFAIK IPAL relies on a traditional pressure sensor not a laser... but yes, you just described IPAL.
Teunos
Its now a new idea, it has just never been widely implemented. Philips did it decades ago with their motional feedback. Great impulse responses on those cabs, although the use was very limited to strict small low-power hifi cabs, they made some great cabinets.
Best regards,
Teun. |
ceharden
Laser measurements are commonly used by driver manufacturers to look at cone motion.
70,s hero
yer but, IPAL is only a sub system, sub systems are mostly distortion, they can get away with an acclerometer as the frequencies are very low, I am taking about a full range system.
Just about all speakers enclosures are designed to give a maximum performace and it is a tricky ask sometimes. I am asking the question.... why would you not control the cone at source as opposed to relying on loads of air.... well in combination with the enclosure. At present we have a whole array of SMS settings designed to get the best out of our cabs. By deriving accurate response data from the cone a simple data set would select the enclosure parameters based on a sweep or two. The information could then be used as previously discussed to practically eliminate distortion within the system.
Top banana
Hvedstrup
Registered User Joined: 30 October 2009 Status: Offline Points: 413 |
Once i i got the Coda Audio 4x18" SC8 sub demonstrated. The funny thing is that i moved insane amounts of air, but the lack og distortion made is sound like "less".
It seems that a certain amount of distortion on subs is desirable. |
fede
Registered User Joined: 07 April 2013 Status: Offline Points: 18 |
You can fix cone movement if you are in the piston range only..and also if you implemented this in digital domain you must have a very very fast processor.. No easy
Federico |
fede
Oh yes and this has a name: Missing fundamental Federico |
70,s hero
Quite a few posts on here are about sound quality be it driver or enclosure specs, as we know,the perception of loudness is derived from the amount of distortion that a system produces. Systems driven to a level where they produce listener fatigue are IMO ok if you roll that way but I prefer a reasonably defined sound. As you say, driving subs relatively hard does produce that feel/punch ... whatever... sound that people like, it would be good to get that without distortion. In the same way, both mid and high would benefit from less distortion in P.A. systems or at least some of them. I see no reason why this can not be done with current technology |
Top banana
Old Croc Joined: 02 April 2004 Location: United States Status: Offline Points: 5172 |
This does not require current technology. It requires common sense. The majority of providers do not carry enough equipment to cover the area properly. This is precisely the reason they present a lot of distortion for they are overloading their system. As the old saying goes “There is strength in numbers.” When you have more than enough amplifiers and speakers to cover area with ample amounts of headroom, you will have all the volume you need with very little distortion. Best Regards, |
studio45
So your man could make a laser widget that attaches to the driver chassis somewhere. not requiring to be aimed at the cone from outside, no? Because something like that would be *much* easier to retrofit to existing drivers than any kind of accelerometer. I've been tilting at that myself, but quite discouraged by the problems of mounting the sensor somewhere it receives the relevant information, without potentially interfering with cone movement or cosmetically damaging driver cone.
