  New Posts New Posts RSS Feed - LEM DX 24 set up
LEM DX 24 set up
nuclearbass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuclearbass Quote  Post ReplyReply Direct Link To This Post Topic: LEM DX 24 set up
    Posted: 15 October 2010 at 3:34pm
Ive recentley started building my own system up bit by bit (when the cash allows), i have bought a lem digital cross over and i get the basic functions eg setting itup 2 way for my system & gains / outputs etc, but im unsure of how to set it up to get the best out of my speakers, im currently running 2 x fane 18XD bins for bass & 2 x intimidation ak215, not the best set up in the world i know, but i am just starting out, im just unsure how the x over bit needs to be set up more than any thing, if any 1 has one of these or has the know how it would be much apretiated
thanks rich
Stray-Sounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stray-Sounds Quote  Post ReplyReply Direct Link To This Post Posted: 15 October 2010 at 4:46pm
I have a dx26+ probs quite similar. I can try and help, how is it set up at the mo?
If the tops are channels 1 and 2 and the subs on 3 and 4 I would try
LPF THRU
HPF LR 24
100hz
on channels 1 and 2
HPF LR 24
30hz
LPF LR 24
100hz
on channels 3 and 4
Just to get you started, then play with it until it sounds good.
Hope this helps and is roughly what you were asking Embarrassed
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuclearbass Quote  Post ReplyReply Direct Link To This Post Posted: 15 October 2010 at 5:07pm
hi old croc :p,  thanks al have a look after the weekend, very much apretiated. i do remember seeing those numbers and settings but wernt sure how to set it up so that may be very helpfull....
Al let you know how i get on.....
:D thanks again Rich
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stray-Sounds Quote  Post ReplyReply Direct Link To This Post Posted: 15 October 2010 at 5:28pm
Yeah it should look on the screen roughly as I have written it
