  New Posts New Posts RSS Feed - Letterbox X1 plan
Letterbox X1 plan
 Post Reply Post Reply Page  <1 4567>
Daily Crisis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daily Crisis Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2014 at 12:51pm
Originally posted by angus angus wrote:
here it is. Didin't do too much and it looks pretty similar. No dimensions for back plate as I don't have a driver to hand and have never built one of these cabs before, but you'll probably have to put the driver in diagonally.
Front view:
Side view:
(Wood is 18mm birch ply)
Hope it helps someone.
Cheers,
Angus
Thanks
DAILY CRISIS
Gfoster View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gfoster Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2014 at 1:22pm
I certainly like the look of the X1's will these work well with a top for band/theatre work?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daily Crisis Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2014 at 2:10pm
Front view:
Side view:
Cheers,
Angus
Where can I get 18mm birch ply from?
(in the UK)
Is there any other woods I can use?
DAILY CRISIS
all bass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote all bass Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2014 at 3:01pm
(in the UK)
B&Q ?!
nigelhoff View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nigelhoff Quote  Post ReplyReply Direct Link To This Post Posted: 19 April 2017 at 7:56am
the link to the sketchup draw of this is dead understandably. Anychance someone could reupload it?.
Keen to see if a
P.Audio P180/2241MkIl will fit??
Thankyou
Post Options Post Options   Thanks (0) Thanks(0)   Quote nigelhoff Quote  Post ReplyReply Direct Link To This Post Posted: 05 June 2017 at 11:30pm
I have been building two X1's letterbox. i am loading them with P180/2241 mkII they are a really tight fit. i will upload some pics when im done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nigelhoff Quote  Post ReplyReply Direct Link To This Post Posted: 05 June 2017 at 11:33pm
photos below:
Edited by nigelhoff - 05 June 2017 at 11:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote nigelhoff Quote  Post ReplyReply Direct Link To This Post Posted: 05 June 2017 at 11:34pm
https://ibb.co/bMexVv -
Post Options Post Options   Thanks (0) Thanks(0)   Quote nigelhoff Quote  Post ReplyReply Direct Link To This Post Posted: 05 June 2017 at 11:36pm
https://ibb.coP0Mqv -
ellm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ellm Quote  Post ReplyReply Direct Link To This Post Posted: 09 March 2020 at 8:36pm
Sorry to jump in on this old thread. I'm new to the forum.
Just wondering how these cabs perform frequency wise in comparison to the original X1s? I'm looking to build a similar pair but with flared ports (to be loaded with Void V18-1000s).
Many thanks:)
Noyzmunky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Noyzmunky Quote  Post ReplyReply Direct Link To This Post Posted: 09 March 2020 at 10:35pm
they should be the same. same volume, same ports and port length. just the shape changes. I have not A/B tested though.
my name is Inigo Montoya...you killed my father, prepare to die!.
ellm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ellm Quote  Post ReplyReply Direct Link To This Post Posted: 23 March 2020 at 4:00pm
Brill, thank you!
