  New Posts New Posts RSS Feed - Lev_RS_1220 Scoop
Topic ClosedLev_RS_1220 Scoop
 Post Reply Post Reply Page  <12345 19>
RealitySound View Drop Down
Direct Link To This Post Posted: 15 March 2012 at 11:40pm
Solid buildThumbs Up I'd go with the ass style brace personally. The horizontal bit is far more important that the vertical. I'd go straight back then angle up a bit where the scoop comes down from the back. As far as I know the crossbracing is alot more for stopping the box resonating/vibrating more than anything. If your feeling creative you can do a brace like the superscooper, then where its horizontal brace ends (15degrees) you can extend it up towards the back of the scoop at an angle too (like the rx18) Others may have other suggestions, but thats my 2 cents.
Yamon.
We learn something every day, and lots of times it’s that what we learned the day before was wrong.
Ras Loud View Drop Down
Direct Link To This Post Posted: 15 March 2012 at 11:46pm
Maybe this is a stupid question, but are there actually also people who want their scoop rather resonating/vibrating and leave the mouth bracing out for that reason?
Direct Link To This Post Posted: 15 March 2012 at 11:59pm
I swear I read that somewhere too. I think some people just don't think its a big deal or just can't be bothered. When in doubt, I look at the best scoops on the market. They're all heavy as hell because there braced like crazy. Look at the rx18 for example, double 36 mm bracing throughout entire cab, and Tony drops hints constantly all around these forums that when it comes to differences between scoops innards moving things a cm here or there your not gonna get a huge difference in the output of the cabs, but bracing def does help. If u flog your scoop and touch the sides and feel it shaking/vibrating, just think that bass/pressure could be coming out the scoop instead.
Direct Link To This Post Posted: 16 March 2012 at 12:07am
Cool. Maybe we'll make a comparison after the second one is built, run one with and one without and see if we can hear a difference.
TONY.A.S.S. View Drop Down
Direct Link To This Post Posted: 16 March 2012 at 1:04am
Interesting thread, Just in case you're wondering about the angles of the braces in the RX18, all I did was draw a centre line between the two walls of the horn and thats where I placed the braces. This was to ensure that the open end of the horn was braced evenly.
Plans? whad'ya mean plans! I thought you said you was a designer.
levyte357 View Drop Down
Direct Link To This Post Posted: 16 March 2012 at 1:14am
EDITED
Edited by levyte357 - 11 May 2012 at 1:41am
Direct Link To This Post Posted: 16 March 2012 at 1:45am
Tony do you feel the angles of the horizontal brace has an impact of the direction/ or any influence of the bass/ sound pressure coming out of the mouth? I felt the superscooper brace's upward angle would throw the back pressure up towards the driver and its forward pressure causing a slight bit more cancellation than there already was versus your straight out style.
Direct Link To This Post Posted: 16 March 2012 at 9:30pm
Jah Tubbys also uses a horizontal brace without an angle:
http://www.flickr.com/photos/kibir-la-amlak/6781782413/in/set-72157627354577762
The only other thing I wonder about are the vertical braces inside behind the front chamber and to the back. All the old plans have only one vertical brace in the middle, but Jah Tubbys and RealitySound both double brace these sections. Am I right that this is only to make the whole construction more stable and has no influence on the sound?
Direct Link To This Post Posted: 16 March 2012 at 9:47pm
I would say that is correct. Thumbs Up
The first little pig built his house out of straw because it was the easiest thing to do.
The second little pig built his house out of sticks. This was a little bit stronger than a straw house.
The third little pig built his house out of bricks.
All depends what you want to do, but a scoop built with bricks would play the loudest!
Direct Link To This Post Posted: 16 March 2012 at 9:53pm
Another question to Tony (maybe a little bit off topic): Do you know if there is anyone in the Netherlands who uses any A.S.S. scoops? I just realize that I already heard all kinds of scoops, but none of these as far as I can remember.
bee View Drop Down
Direct Link To This Post Posted: 16 March 2012 at 10:35pm
the wave lengths are too big for a an angle brace to have any real effect on a scoop at the mouth.... but bracing is a must.....
@ ras loud yes, 2 braces are better than one, a single double brace should be fine (36mm), or 2 18mm braces....
one thing to remember is if your front baffle is 36mm thick, for strength and support, this is under the same stresses as the back section behind it...... a double brace gives twice the support....
Direct Link To This Post Posted: 17 March 2012 at 1:39am
The braces can't have an influence on direction. They are there to make sure the open sides are held tight and the resonance high. That way there is minimal colour added. The waves emitted are too large to be influenced by the braces or the shape. If there were complete short wave lengths in the horn, then the waves would reflect off at a tangent, in other words, the in coming angle would be the same as the out going one. It helps if you have a vision of sound waves traveling and the relationship of wave length V
size of object placed in front.
web department
