Lightweight Neo Build |
lutkeveld
Thanks(1)
Posted: 12 March 2015 at 4:01pm |
Hi guys. I'm planning a lightweight build for in the summer. I've got my battery setup together: 11.1V 3.4Ah 18650 Panasonic pack with a 1.5A charger and balancing protection module. Now I'm looking for drivers but can't really decide. It has to be lightweight, so probably neodymium based, work good in <4 liter and be cheap (<40€). My 2 main candidates:
-Faital Pro 3FE22 ported -Dayton ND105 sealed With the Faital the bass extension isn't that great, but it's very efficient and can be compact. Although it needs to ported (or a PR), so that has to be compensated for. It can very well work fullrange The Dayton has decent bass extension but doesn't really want to be a fullranger and isn't that efficient. I'm wanting to use it with the Lepai so I can EQ up the bass a bit if I want. Or use the capacitor resonator trick like in the Boominator Micro. Can anybody help me make the decision? |
Sapro2
Registered User Joined: 31 January 2015 Location: Somerset Status: Offline Points: 354 |
I would say that efficiency is key for 12v systems so of the two i would reccomend the Faital. You can either have it a bit quieter taking advantage of your efficiency or alternatively have it louder: remember that 3db in efficiency is double the power. If you are outside, unless you have a lot of it then deep bass will blow away and disappear anyway.
Edited by Sapro2 - 15 March 2015 at 2:18pm |
Splat Soundsystem
Baby Sham pram Soundsystem Sapro - SoundCloud https://soundcloud.com/sapro DJ Sapro. West country free party DJ and Producer. |
Hemisphere
Efficiency is definitely key to 12v although I've found this mantra if followed to the letter can be counterproductive to good design. It's one of the first things I learnt but equally it made me overlook a lot of amazing components for no better reason than a couple of dB less efficiency than the - inferior - alternatives. Sometimes a component will be so good for portable applications (lightweight, cheap, great sound quality and quite good but not stellar efficiency) it's worth the extra battery/amp power requirements to make it perform.
Edited by Hemisphere - 15 March 2015 at 3:53pm |
lutkeveld
Yeah, I thought about that too. 3dB doesn't seem to be the end of the world, and a bit of bass extension is always nice. Especially for the occasional indoor use. Of course aiming for a solid 40Hz with 3-4" is stupid, but a F6 or F10 of ~50Hz would be nice.
KWB75
Registered User Joined: 10 November 2007 Status: Offline Points: 259 |
Totally agree, whilst efficiency is important I quickly realised that personally I don't need massive output or long battery life. 99% of my music is played at medium/low volume for <5 hrs, this really doesn't put efficiency at the top of design priorities.
Look at the minirig sub - uses a driver with a sensitivity of 76db, can't be many drivers worse than that - yet it's an incredible little speaker. |
lutkeveld
I really can't find a driver like the Faital that trades efficiency for bass extension.
Neodymium magnet, low price, good high freq response, efficient, 4 ohm. What do you want more? Yeah, bass. I think I'll just order a pair and see if they produce a satisfactory sound. If not, I'll just sell it. |
Hemisphere
Use Maxxbass or similar harmonic exciter plugin to fill out the frequency response - it won't be as good as 'real' bass but it'll give a decent approximation and makes sure the low bass content isn't lost altogether
lutkeveld
Can't seem to find any for Android
Hemisphere
I don't think there are any 'live' filter apps that you can run the signal through, you need to use a DAW (Reaper is a good 'free' one) and either play your music directly through that or filter it with the plugin and export to WAV. The MaxxBass plugin is available as a free time limited trial from Waves, that should be enough to convert a lot of files
