Limiter Setting on the Berry Utlradrive DCX 2496 |
Tobie
Joined: 30 June 2011 Location: Kent Status: Offline Points: 54 |
Topic: Limiter Setting on the Berry Utlradrive DCX 2496Posted: 21 February 2012 at 1:25pm |
Hi I have a feeling this has come up quiet a few times as the instruction book is some what @ best VAGUE so sorry for the post again.
I just want to know how set the limiter setting using the math way I.E using input sensitivy / RMS of speakers / RMS of amp etc.
I have the way where you simply turn up the unplugged amp until it clips then turn the settings on the Berry until the limiter kicks in I'd rather use the math way as I think this wil be more precise, here is the details of the Subs I want to limit
Sub
A pair of Opus SB215 800RMS each cab @ 4Ohms
Amp Opus HD1500
600 RMS @ 8 Ohms Per channel
1200 RMS @ 4 Ohms Per channel
2500 RMS @ 2 Ohms Per channel
Input sensitivity +6DB
1.4 Volts @ full power
So the amp is running @ 1200RMS each channel and the sub needs 800RMS
If someone could tell me how to arrive at the correct figure and also what that figure is so I can make sure I am doing correctly
Thanks Very Much for your time
Ta
djeddie
Joined: 26 April 2004 Location: Bristol Status: Offline Points: 2029 |
Posted: 21 February 2012 at 1:41pm |
Have a search of the forum as there are a couple of very good guides on how to do it. I'm sure they're from the last few months as well.
E=mc² ±3dB
SebP
Joined: 02 February 2010 Status: Offline Points: 78 |
Posted: 22 February 2012 at 1:17am |
simonh
Joined: 07 November 2010 Location: Essex Status: Offline Points: 345 |
Posted: 22 February 2012 at 10:26am |
Also, take a look at AlfieDring post. I used the same methodology to work out my limiter settings and then I added a bit more on - rather be safe than sorry... |
Tobie
Posted: 22 February 2012 at 1:17pm |
thanks for all your help
the links in en francois but i think i've got the hang of it ill go home and try the maths way and see if it comes out the same result
ta
dj haydn
Joined: 30 September 2011 Location: wiltshire Status: Offline Points: 405 |
Posted: 24 April 2012 at 12:27am |
is it me or is the link not working???
earwax sounds
SebP
Posted: 24 April 2012 at 3:59am |
Edited by SebP - 24 April 2012 at 4:00am |
Tweet
