Limiting amplifier output via LMS |
Post Reply | Page 123> |
Author | ||||
Futendra
Registered User Joined: 28 April 2016 Location: Belgium Status: Offline Points: 276 |
Posted: 18 May 2017 at 11:15pm |
I want to limit the output that goes out of our DCX2496, so we would never be able to to blow our drivers by driving our amplifiers too hard.
We will be using a Behringer Europower EP1500 and a TSA 4-1300 to power our TMS-3s. 2" HF Driver: RMS: 75W Impedance: 16 Ohm Calculated ideal amp power: 16 Ohm 120W / 8 Ohm 240W Amp we will be using: Behringer Europower EP1500 Amp power: 8 Ohm 260W 2x 10" MF Driver (Calculated together in the manual): RMS: 200W Impedance: 8 Ohm Calculated ideal amp power: 8 Ohm 320W Amp we will be using: TSA 4-1300 Amp power: 8 Ohm 1220W 2x 15" LF Driver (Calculated together in the manual): RMS: 500W Impedance: 4 Ohm Calculated ideal amp power: 4 Ohm 800W Amp we will be using: TSA 4-1300 Amp power: 4 Ohm 1670 W How do I do this correctly? Edited by Futendra - 18 May 2017 at 11:16pm |
Conanski
First You have to figure out what the gain differences are going to be between the drivers because it's likely the HF will totally overpower the other two acoustically if run at the same gain. This is where the driver efficiency factors in, a 2" CD on a horn could have a 1w sensitivity of 108 while dual 10's might only do 102dB so the CD gain will have to be 6dB lower than the mids to produce a balanced output... assuming the the two amplifiers have the same total gain as well. Do they? EQ could also change this slightly but readjust again after you get the the system into the right ballpark.
How are you determining that "ideal amp power"? Is that 200w RMS for the mids per driver of for the pair? Same question for the LF, is that 500w for a single driver or the pair? In either case why is the ideal less than 3dB above RMS? Is this for an EDM system or something? If it is then that is cool.. you want to limit a little over RMS but for other types of music the limiters could be opened up quite a bit. Edited by Conanski - 18 May 2017 at 11:59pm |
Futendra
Driver gains: HF: -2 dB LF: 0 dB LMF: -2dB How do I find out if the amplifiers have the same total gain? I'm a bit confused
Ideal amp power is 1.6x RMS wattage. This is usually under the program wattage. We determined it this way because we are going to play harder genres. I think the wattage is for a pair. Not sure though, here is the manual: http://www.kirsch-akustik.de/downloads/tms3.pdf
It is for harder genres. Tekno, hardcore, breakcore, terror, acidcore, ... Edited by Futendra - 19 May 2017 at 12:36am |
Conanski
Futendra
Can't find anything about total gain in the amplifier specs...
Conanski
Yeah it is in there. T-amp TSA-4-1300 Input sensitivity: 0.775v(0dB)/1.4v(5.1dB) switchable Voltage amplification(gain): 37.8dB Behringer Ep1500 Input sensitivity: 1.14v(3.4dB) Voltage gain: 32dB Looking at the input sensitivies for a moment, what this means is that if you were to connect the amps directly to your mixer you would need to push the main output to +5dB to get the t-amp to full output(when it is set to 1.4v sensitivity), while the Behringer would only need +3.4dB for full power. But you don't want full output from the t-amp you want roughly half or 3dB less than full so that number drops to +2.1dB on the mixer. |
Futendra
I don't understand much of that. Math has never been my best skill.
We will be plugging the amps in the DCX, of course. |
APC321
Young Croc Joined: 24 August 2013 Location: West Midlands Status: Offline Points: 684 |
A simple non-technical check to see if you have done things right:
1) Get the DJ mixer that you will be using with your rig. 2) Connect it up to your LMS and amps. Do not connect the speakers. 3) Play some tunes through the DJ mixer and max out all the eq, and red line the masters on the DJ mixer. If none of the clip lights light up on your amps (or just flash occasionally with the music on bass or sub) then you will be fine. |
Futendra
It's not really about making redlining safe, we want to make sure we won't blow our drivers, because the amps we are using give quite a lot more power than necessary. |
4D
Think about use the input gain on ab & c inputs, and output gains on the six outputs for setting the gain structure correctly to maintain dynamic range without overpowering the speakers or driving the amplifiers into clip and then use the limiters as a final brick wall. https://musicgroup-prod.mindtouch.us/04_BEHRINGER/How_Do_I_Set_Up_My_DCX2496_Unit%3F Edited by 4D - 19 May 2017 at 8:50pm |
Futendra
So if I set the LMF and MF output to +2.1dB gain on the DCX, I will actually be safe when driving the amps "full power"? Or what does that mean?
Futendra
So I should set the LMF and MF gain to +0.1dB (in order to have the right balance + restricting the wattage output of the TSA 4-1300) and set the HF to +3.4dB (for actual full power on the EP1500)?
