Line array Project |
Page <1 91011 |
coyote
Joined: 12 February 2007 Status: Offline Points: 65 |
Posted: 20 February 2010 at 2:51pm |
Blackcat, What was the result? |
xvsolutions
Joined: 09 September 2010 Location: malta Status: Offline Points: 1 |
Posted: 09 September 2010 at 10:55pm |
hi
i am interested in trying to build this cabinet ..can you send me propper dimensions ?
thanks
BlackCat
Joined: 13 November 2006 Location: Russian Federation Status: Offline Points: 49 |
Posted: 10 September 2010 at 6:29am |
Hi
well, i did some "restyling" of my line array at the beginning of the year. Satellites was changed, they are 2-way instead of 3-way, cabinets built from 14 mm plywood intead of 18 mm. Cabinet weight in assembly is 22 kg. HF section has additional flares widening horizontal covering of HF to 90 degrees approx. MF horn flares made from 5 mm plastis inserted into slots made with router in top and bottom walls of tne cabinet. Subwoofers remained the same. All cabinets including subwoofers has carpet coating. |
BlackCat
Posted: 10 September 2010 at 7:06am |
to xvsolutions: can`t see Your email...
ryanbairan
Joined: 29 September 2008 Location: asia Status: Offline Points: 63 |
Posted: 18 September 2010 at 9:40am |
any one have a plan for dual 12 array?
lukelucas93
Joined: 05 July 2011 Location: Carlisle Status: Offline Points: 523 |
Posted: 03 January 2012 at 4:11pm |
I was surfing and managed to find this
http://www.ebay.co.uk/itm/FILA-1000-line-array-kit-Pro-Audio-loudspeakers-/300644838600?_trksid=p3286.m7&_trkparms=algo%3DLVI%26itu%3DUCI%26otn%3D3%26po%3DLVI%26ps%3D63%26clkid%3D5351061908408115449#ht_500wt_1202 Its like a kit ! plans flying gear is all included |
If its too loud... Your wayy too old...
BlackCat
Posted: 04 January 2012 at 6:12am |
Heh, our chinese brothers are really good! And who knocked me for my flying rig?
JD01
Posted: 06 January 2012 at 10:42am |
The flying gear from that ebay link is interesstin, the flare not so much. There is no waveshaper in the HF horns and no phaseplug in the mid horn, so there is advantage in terms of vertical coupling against the 12".
CCAV
Joined: 25 October 2010 Location: North Carolina Status: Offline Points: 130 |
Posted: 06 January 2012 at 2:30pm |
I contacted Jeff at this company and here are his recommendations for drivers for his LA box Hi William, The recommended Driver are as follows:
The recommended 1” drivers the Eighteen Sound ND1075 (but
this one is subjective to taste) but I prefer the Beyma CP385/Nd
The recommended 8” drivers the Eighteen Sound 8NM610 (closed
back) RCF - MR8N301 (Closed back)
The recommended 12” drivers the Eighteen Sound 12ND930 neo
but I would go with an ceramic equivalent
The rigging is set at a 10:1 safety ratio and with the
present available design on our site, it can hang up to 24 box deep with
stainless steel QR pins. Others only have a 7:1 to 8:1 factor but w e over
engineered with safely first in mind.
Thanks
Jeffrey A. Forsburg Forsburg Industries corp. 919-606-3443 |
In my early years my favorite phrase was "If it's too loud your too old" Now I'm just too old
kevinmcdonough
Joined: 27 June 2005 Location: Glasgow Status: Offline Points: 2534 |
Posted: 06 January 2012 at 5:42pm |
see, now that makes it a bit more interesting.
The fact that he specs it with a decent, relitivly expensive brand of drivers like 18 sound, which many outside of the direct pro audio industry wont have heard of, actually shows he may know his stuff a little and makes me like the look of this all the more. Even just two or three of them a side ground stacked on some subs would be interesting. While at that length of line they would basically just be vertically stacked reflex boxes and not a proper line array behaviour as such, they would give you the line array "look" and a with that quality of drivers still be a fairly potent and im sure great sounding system. k Edited by kevinmcdonough - 06 January 2012 at 5:53pm |
Page <1 91011 |
Tweet
