line array |
Post Reply | Page 123 4> |
stanley dj
Registered User Joined: 19 July 2013 Location: Ireland Status: Offline Points: 154 |
Posted: 16 April 2014 at 11:23pm |
hi any recommended cabinet desighn for line array ? im goin to buil 12 boxes each box will have 2x eminence delta 12B and selenium d220ti thanks all
Edited by stanley dj - 16 April 2014 at 11:23pm |
MarjanM
That wont work!
stanley dj
what will work?
bitSmasher
Old Croc Joined: 23 June 2012 Location: Melbourne Status: Offline Points: 2295 |
Take this design and make it larger for 12"http://forum.speakerplans.com/2-x-10-1-x-2-line-array-plan_topic85913.html
MarjanM
HF driver will need to go as low as the 1/4 wave lenght of the distance between the two 12 inches to be able to couple. probably at around 700-800zh. That selenium driver can not do that.
No one is stopping you do execute your idea, but that box will not be a line array. It will make some noise, it might even sound nice, but it will not work as a line array.
t.geessounds
Young Croc Joined: 10 May 2010 Location: US... New york Status: Offline Points: 908 |
http://forum.speakerplans.com/diy-compact-line-array_topic15820.html
or this one
all bass
Here's something Staiper designed some years ago. Going 2x12" is going to be a whole different story though. |
stanley dj
and if i use 2x 10 inch drivers?
MarjanM
in any case, you either need two very beefy hf drivers or you go 3 way.
stanley dj
if i go to 2x 10 inch eminence delta 10b (16 ohm ) and one selenium d220ti witch mid drivers u will recommended ? and 2 or 4 ?
MarjanM
how do you plan on getting away with only one HF?
Pasi
Old Croc Joined: 25 April 2010 Location: Knutsford Status: Offline Points: 2732 |
And also, do you guys realise that line array can not be used efficiantly without aiming software as it doesn't work "point and shoot" way like the point source stuff works? More you curve line array, more difficult it is to predict without software how the sound actually behaves.
