Little system |
jackSpug
Joined: 31 January 2009 Location: south wales Status: Offline Points: 171 |
Topic: Little systemPosted: 15 February 2012 at 11:40pm |
Im building a little system comprised of four MS18-MK3 loaded with Void v1000 powered by xp5000.
4 hds loaded with kappa lf2 powered by xp3000. 3 mt130 loaded with pd121 and selenium d205ti comps, mids run off str2000 and highs of ukp1000. Do you think I have enough headroom on the voids? any advice overall? |
two people use this account
Tocooltom
Joined: 07 March 2011 Location: Narrrfuk Status: Offline Points: 992 |
Posted: 16 February 2012 at 9:11am |
That should be fine as it is, but if you want to push your scoops and make them loud as possible then you could do with a bigger amp.
Lucid Dreaming :)
TechnoChef
Joined: 23 April 2009 Location: Oxfordshire Status: Offline Points: 1037 |
Posted: 16 February 2012 at 5:56pm |
"I'm building a little system"
Understatement of the year, that'll be a stonking setup!
Tocooltom
Posted: 17 February 2012 at 8:07am |
+1 that system will be pretty big when its all done! |
Lucid Dreaming :)
jackSpug
Posted: 20 February 2012 at 1:52pm |
Nice one guys! ill try get some pics of the build and finished system on here
jackSpug
Posted: 24 February 2012 at 3:07pm |
Another question! I am learning... slowly..
![]() Obviously I want to build the scoops out of 18mm voidless birch but expensive. Not keen on mdf because it just falls apart and heavy! Am I wasting all the quality of the decent drivers and amps by using standard ply? Unless someone knows where I can get decent ply cheap? Also is it necassary to use 18mm ply for building the mid/tops? trying to minimise weight of the system overall and I think that 15mm would do the job? |
hmaudio
Joined: 03 April 2009 Location: Nottingham Status: Offline Points: 2679 |
Posted: 24 February 2012 at 3:25pm |
little system!! its twice the size of mine already
have a shop around at local wood yards and see what you can get hold of, as for the tops 15mm is fine just make sure you ajust your cutlist -3mm
We all start from the bottom, very few, in comparison, make it to the top.
![]() This account is used by 2 people. |
Tweet
