LMS - raising crossover db or reducing output db |
Author | |||
IainB
Registered User Joined: 25 November 2016 Location: Rushden Status: Offline Points: 422 |
Posted: 27 March 2017 at 6:31pm |
Quick question and im sure there is a very good reason (I just dont know what yet)
Playing around with levels between my tops and bins. My LMS allows me to increase the db at crossover level, or reduce the individual channel outputs My current setup is admittedly top heavy. So for the current forum LMS newbie, whats the difference between boosting the 40-100 crossover for the bins or reducing the output on the tops? Thanks (again) for helping with todays stupid question
cravings
what is your lms? are you sure the db setting at the crossover points isn't the slope? (12db, 24db etc) sorry if that's an oversimplistic answer and of course you're not confused about that hehe.
IainB
Its a Peavey VSX266 which has zero userbase! (though im going to regret all my posts about the bloody thing when I come to sell it and someone googles VSX26!) Its definitely raising levels as I was playing on the fly before I took everything down ready for the weekend, its not the 12/24 slope on the crossover that much I do know. I may well be missing something, though I have noticed on each output I can only reduce db, not increase. Crossover allows increase, so maybe Ive just answered my own question
Conanski
Old Croc Joined: 26 January 2006 Location: Ottawa, Canada Status: Online Points: 2545 |
IainB
Thanks, ever so slowly getting my head around this. Now to go an search the Peavey forums and see what increasing / decreasing does, fingers crossed there is a post hidden somewhere with the details (as the manual is next to useless with information)
Pinyorouk
Young Croc Joined: 31 January 2011 Status: Offline Points: 551 |
Maybe try and read a more comprehensive manual of a different LMS and then apply it to yours. There is nothing that I saw unique to that LMS compared to others. Terminology may be slightly different but you could work it out through a block diagram.I found it easy to understand after starting off with a Behringer and Void Digidrive V1
ewan360
New Member Joined: 12 December 2012 Location: Surrey Status: Offline Points: 5 |
The VSX has a user base of at least two - you and I!
Pinyorouk is quite correct, there's nothing particularly different in the way the VSX works to any other LMS, and I've used a few. The gain on the crossover and the output attenuator are both in the digital (pre D-A converter) domain, so it really doesn't matter where you do your balancing, as long as you don't clip, which is unlikely, as there is enormous amounts of headroom on this unit. Having said that, the more output you get, the better the signal-to-noise ratio, which is an issue on this unit as it has such a huge output signal. Hence why I turn my amps down half way, which makes setting the output compressors/limiters up virtually impossible. I could probably burn some midnight oil working it all out, but it would always nag me that it might not be correct, and hard compression/limiting in the wrong place can be just as damaging to speakers as none at all. Ewan |
IainB
That is awesome news Ewan I thought I was the only one over here lol May have also sussed the 'dodgy' output on this... think its a bad lead, as it did it at the gig on Saturday, after passing a successful sound check. 2 hours later after going out for food and 1 channel has dropped... again. Leads were the one thing I didnt check last time (user error on my behalf) so thats on the list of things to sort before the next one
