LMS Stuff |
nickyburnell
Posted: 05 September 2016 at 9:23pm |
Sometimes I see people saying that a certain frequency needs to be reduced for a cab (+q etc), even though the cab is crossed over way lower than that frequency. I presume this is some sort of overlap due to slope? Is this correct?
AndyWave
Registered User Joined: 30 March 2008 Location: Finland Status: Offline Points: 380 |
Least I do it as routine procedure with iir filters, suppressing out of band resonances. Also may affect phase response depending filter modeling inside the LMS unit.....
I suppose you mean something like using 180Hz notch filter on sub channel with crossover points somewhere 25 and 98 Hz? At least nearest full octave above/below xo freq. may well benefit of notch or two. my 2p |
torturing electrons since ......
nickyburnell
I suppose you mean something like using 180Hz notch filter on sub channel with crossover points somewhere 25 and 98 Hz? At least nearest full octave above/below xo freq. may well benefit of notch or two. my 2p [/QUOTE] Exactly that.Ta |
