  New Posts New Posts RSS Feed - LOADS OF NEW DESIGNS
CHAMPION View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CHAMPION Quote  Post ReplyReply Direct Link To This Post Topic: LOADS OF NEW DESIGNS
    Posted: 27 November 2004 at 11:27pm
Ladys and Gents, here are some new designs i have come across, enjoy:-
The EV MTL Cab Design
http://www.geocities.com/loudspeakerguru/TL4050SPEC1.jpg
http://www.geocities.com/loudspeakerguru/TL4025SPEC2.jpg
http://www.geocities.com/loudspeakerguru/TL4025.jpg
http://www.geocities.com/loudspeakerguru/TL4050.jpg
http://www.geocities.com/loudspeakerguru/TL4025.gif
The Fane Double 15 Folded  Horn
http://www.dancetech.com/aa_dt_new/pa/plans/2x15-folded-prin t.gif
LabHorn Design
http://www.prosoundweb.com/lsp/horn_asm_1.pdf
JBL 4530 15" Scoop
http://members.aol.com/xxbase80a/rutsche.1.15/bau.html
JBL 4520 2x15" Scoop
http://members.aol.com/xxbase80a/doppelrutsche.2.15/bau.html
Shearer  2x15"
http://members.aol.com/xxbase80a/shearer.2.15/bau.html
http://www.hornloudspeakers.de/EIndex/EPA/EShearer/eshearer. html
2x15" W-Bin
http://members.aol.com/xxbase80a/w2.15.bin/bau.html
http://mitglied.lycos.de/crusher844/box/215wbin.gif
University Classics
http://www.geocities.com/loudspeakerguru/CorrectedUniversity Classic.gif
http://www.geocities.com/loudspeakerguru/UniversityClassic.j pg
Voice of the Theater
http://members.aol.com/xxbase80a/voice.of.theatre/bau.html
EighteenSound Vented15" Bass Bin
http://www.eighteensound.it/pdf/applic/BR115.pdf
EighteenSound Vented18" Bass
http://www.eighteensound.it/pdf/applic/BR118.pdf
EighteenSound 18" Bass
http://www.eighteensound.it/pdf/applic/BPH118.pdf
EighteenSound Double 15" Vented
http://www.eighteensound.it/pdf/applic/BR215.pdf
EighteenSound Double 18" Vented
http://www.eighteensound.it/pdf/applic/BR218.pdf
Selenium 2x15" bass (long throw)
http://www.selenium.com.br/site2000/trio_eletrico/pdfs/HB150 2B12.pdf
Selenium 12" Mid/high (long throw)
http://www.selenium.com.br/site2000/trio_eletrico/pdfs/HB120 5A3.pdf
Selenium Project
http://www.selenium.com.br/site2000/trio_eletrico/pdfs/Frent e_Fundo.pdf
Selenium Subgraves
http://www.selenium.com.br/site2000/subgraves/pdfs/subgraves 1.pdf
Selenium 15"+12"
http://www.selenium.com.br/site2000/discoteca/pdfs/Discoteca 1.pdf
Selenium PROJECTS (page contains pdf files to all projects)
http://www.selenium.com.br/site2000/pas/projeto_pas.htm
Caire website loads of pdf's :-
http://web.archive.org/web/20000615032256/http://www.ciare.i t/Myprospeak.htm
I liked this design : http://web.archive.org/web/19980512092659/www.ciare.it/pdf/M YPROS6-7.pdf
That sould keep you lot busy !!!
i will put sum more up soon.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote CHAMPION Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2004 at 11:28pm
if you have any problems with the links...get bak to me i will sort it out.
freddyi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote freddyi Quote  Post ReplyReply Direct Link To This Post Posted: 28 November 2004 at 12:24am
FAB List of goodies! thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CHAMPION Quote  Post ReplyReply Direct Link To This Post Posted: 28 November 2004 at 6:43pm
having fun ! what do you think of the designs ?
dubsuction View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dubsuction Quote  Post ReplyReply Direct Link To This Post Posted: 29 November 2004 at 10:42am
i like that little double 15" folded horn
peace+respect-always
**HIGH PRESSURE SOUND SYSTEM**
www.highpressuresound.co.uk
PolymorphicMark View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PolymorphicMark Quote  Post ReplyReply Direct Link To This Post Posted: 29 November 2004 at 1:54pm
I've made a couple of those double 15" horns and loaded them with PD1550's. Although needed to extend the back of the cab by about 18mm to get the PD's in. Also added 3 aluminium heat sinks to the removable back panel to chill things out as the rear chamber is quite small. Run a cab up with 1500 watts and they make quite a bit of sound for there size. Not much low bass, but a nice quick kick bass generated. Good for music like techno.
Free to do what i WANT
Post Options Post Options   Thanks (0) Thanks(0)   Quote dubsuction Quote  Post ReplyReply Direct Link To This Post Posted: 29 November 2004 at 2:09pm
cool, i've been making some big 15" folded horns (2m path length) and they seen to play nice low, still awaiting me finnishing the remaining2 to test the stack of 4 (combined mouth of over 12900 cm2).....
....chuffin' big tho!! the living space in my house shrinks by the day!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PolymorphicMark Quote  Post ReplyReply Direct Link To This Post Posted: 29 November 2004 at 3:39pm
what drivers are you going to use for these cabs.
Yeah know what your saying about living space, many would say we're mad. What I say is there's nothing wrong with been keen.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dubsuction Quote  Post ReplyReply Direct Link To This Post Posted: 29 November 2004 at 3:46pm
...couldn't have put it better myself!
...PD 156 in the horns......got them from some dodgey pub install full range cabs.....each cab had 1x PD156 2x phl audio 6.5"  and 8 piezo's...good drivers (except the piezo's) ...sh*t cabs....untill now!
£30/cab got all 4 of em...................sweet
the rear chamber on mine is tight too (ooh err!) how did you do your heat sinks? i'm hoping mine don't burn up and die!
Timber_MG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timber_MG Quote  Post ReplyReply Direct Link To This Post Posted: 29 November 2004 at 3:51pm
I still don't get how someone can pair a PHL mid with a bunch of piezos. At first I though you were posing and taking the piss in a big way, but it seems like you have the ultimate HF torture device to your disposal. How about putting them on top of your tops on a simple baffle just for looks? Get someone in the know totally shocked how a buch of piezos can sound that good
Post Options Post Options   Thanks (0) Thanks(0)   Quote dubsuction Quote  Post ReplyReply Direct Link To This Post Posted: 29 November 2004 at 4:26pm
.....ha ha!!
....excellent idea man! 32 piezo's stuck on a box on top of the stack....scare the sh*t out of anyone that knows the score.....then hide some p.audio compression drivers on horns somewhere cunning and out of site........32 of the f**kers.......i feel like i should do something with em........ maybe make anti dog-attack sirens...... or sell em on ebay with a load of sh*t bigging em up ....
"classic vintage collectable motorolla high frquency units, offer stunning (literally) sound performance with stylish moulded plastic exteriors, midnight black with silver trim, carry the much respected motorolla badge. ultra light weight versions, available for limited period only, a bargain at only £10 per unit..."
.....ok, ok...form an orderly que!!
...i'd be f**king laughin' with 32 o' the little beauties to flog!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PolymorphicMark Quote  Post ReplyReply Direct Link To This Post Posted: 29 November 2004 at 4:48pm
I added heat sinks by constructing the back panel out of two sheets of wood sandwiched together. I cut the back panels out off a piece of 15mm and 9mm ply. For the heatsink material I used three 5mm thick aluminium sheets. I clamped the two back panels together and cut three section out that were 40mm smaller in width and height of the heaksinks. Then using a router set t 5mm depth I routered the edge of the cut-out on the 15mm thick panel  so the heatsink laid flush into it. I then applied silicon to both side of the heatsink where it come in contact with the wood, then screed and glued the 9mm panel on top clamping the heaksinks in place.
Sorry description a bit poor but at work so had to write quickly. Can write a better one tonight if needs be.
Hope this helps.
