  New Posts New Posts RSS Feed - Macrotech MA3600VZ weird fault
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Topic: Macrotech MA3600VZ weird fault
    Posted: 09 August 2012 at 3:48pm
got an interesting one here, wondering if anyone can shed any light.
Crown Macrotech MA3600VZ
Fairly new, clean & tidy.
Problem is, it throws out the main 20A mcb when it's switched off
North Staffordshire
Jimmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jimmer Quote  Post ReplyReply Direct Link To This Post Posted: 09 August 2012 at 4:27pm
plug wired back to front? LOL
Light travels faster than sound....That's why some people appear bright until you hear them speak!
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 09 August 2012 at 4:30pm
Any day an MA3600VZ is not munching drivers, is a good day.
http://i.istockimg.com/file_thumbview_approve/3609938/2/stock-photo-3609938-tiger-eating.jpg
Edited by levyte357- - 09 August 2012 at 6:13pm
Linux, Firefox, Libre Office. Life goes on.
freddymendez View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote freddymendez Quote  Post ReplyReply Direct Link To This Post Posted: 09 August 2012 at 5:00pm
i thought that too!
to clarify do you mean when you switch the amp off (when it was previously switched on), or when you connect the amp to mains with it's switch in the off position?
120-140 bpm, pianos and bass.
diesel, the fuel of professionals.
mendez/manchester
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 09 August 2012 at 5:53pm
Simple solution: tape over the switch and fit it with one of these fancy True1 Powercons, tell the user to switch it on and off with that!
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 09 August 2012 at 6:19pm
Thanks, you've all been most helpful!
It trips the mcb as you are turning it off, whether at the front panel switch or at the wall socket.
North Staffordshire
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 09 August 2012 at 8:03pm
That's worrying because surely to trip as you turn it off at the wall, it must be causing the switch to arc over?
Some kind of fault with the transformer whereby it's storing a massive amount of energy?  Or somehow there is a spike being created on the secondary side and going back through the transformer?  Doesn't sound good either way!
Have you tried it with the old 100W lamp in series with the mains trick and see what happens when you turn it off?
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 09 August 2012 at 11:29pm
Ive had it before with thyristor controlled loads where the thyristors are retriggering due to dv/dt but the 3600 doesnt have thyristor control
North Staffordshire
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 09 August 2012 at 11:56pm
Does it behave normally when it's running?  Any evidence of issues with the VZ circuitry?  Must admit I generally avoid the larger Macrotechs, not my speciality.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 09 August 2012 at 11:58pm
it works beautifully.
North Staffordshire
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 10 August 2012 at 12:23am
All I can say is bizarre!
And good luck!
VentureSound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VentureSound Quote  Post ReplyReply Direct Link To This Post Posted: 10 August 2012 at 5:06pm
Perhaps a faulty MCB?
web department
