  New Posts New Posts RSS Feed - making holes for speakon chassis connectors
amlu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote amlu Quote  Post ReplyReply Direct Link To This Post Topic: making holes for speakon chassis connectors
    Posted: 01 July 2012 at 12:45am
hi, i remember reading a nice long thread on this subject, tried many different search terms but unfortunately nothing comes up.
i have to fix 6 of them into 2mm aluminium sheet.
colint View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote colint Quote  Post ReplyReply Direct Link To This Post Posted: 01 July 2012 at 12:54am
To steal ideas from one person is plagiarism. To steal from many is research.
shagnasty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shagnasty Quote  Post ReplyReply Direct Link To This Post Posted: 01 July 2012 at 2:04am
The Q-max rocks but if you wanna be realy exact with one make a template in a CAD program and tap it to the panel and then use that to align you punch to, makes drilling screw holes easy too...
Something like this taped on, you can centre punch through and then align really tight onto..
Failing that a 22mm holesaw finised with a Step drill or a Cone cutter...Smile
amlu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote amlu Quote  Post ReplyReply Direct Link To This Post Posted: 01 July 2012 at 1:52pm
cheers, will give q max a go :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 01 July 2012 at 2:02pm
There is a device in which you can insert on your drill that will create a hole. Merely, take the Speakon to the lumber mill and, they should be able to find the correct size.
Best Regards,
Edited by Elliot Thompson - 01 July 2012 at 2:03pm
web department
