  New Posts New Posts RSS Feed - Martin atomic 3000w
Martin atomic 3000w
nuclearbass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuclearbass Quote  Post ReplyReply Direct Link To This Post Topic: Martin atomic 3000w
    Posted: 16 October 2016 at 10:57am
Hi guys
One of our Martin atomics has generated an issue as where once it's given hi & fast out out for a few seconds the bulb then severely looses power to around about 25% maybe less output.
Any ideas what could be causing this?
Cheers rich
one life - have fun!
Force fusion pro audio
col_b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote col_b Quote  Post ReplyReply Direct Link To This Post Posted: 17 October 2016 at 8:35am
This is what they do in blind mode.
From the manual - Lamp power is electronically regulated to prevent the lamp from overheating. The intensity falls as power is reduced.
AV, Sound and Lighting and Laser Hire, Sales and Service. www.klsuk.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuclearbass Quote  Post ReplyReply Direct Link To This Post Posted: 17 October 2016 at 6:09pm
Yes i saw that but I would have thought that it could last a little longer before reducing power, when we use 2 linked one dies down quite a bit before the other one, I would have thought they'd go both at the same time
spongebob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote spongebob Quote  Post ReplyReply Direct Link To This Post Posted: 17 October 2016 at 6:15pm
Opened it up and visual'd the board?
Same bulb in both?
James Tengo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote James Tengo Quote  Post ReplyReply Direct Link To This Post Posted: 17 October 2016 at 7:15pm
Any discolouration of the tube? Excessive sooting?
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuclearbass Quote  Post ReplyReply Direct Link To This Post Posted: 17 October 2016 at 9:05pm
checked the boards and they seem ok, not noticed anything on the bulbs will have another check - yes same bulbs in both - from thoman
This page was generated in 0.064 seconds.
