Martin Audio VRS800 Settings and purchase |
Pinyorouk
Young Croc Joined: 31 January 2011 Status: Offline Points: 551 |
Posted: 22 March 2017 at 2:30pm |
Hi,
Could someone please help me with the settings for this 3 way cabinet. Delay between bass, mid, and tops in active mode. EQ and levels too assuming same amplifier gain. I have been able to find settings for VRS 1000 but not VRS 800. Would anyone have some any VRS800 or 1000's for sale with original drivers? Please inbox me if you do. Thanks, Mike |
madboffin
Old Croc Joined: 03 July 2009 Location: Milton Keynes Status: Offline Points: 1538 |
I can't find my notes at the moment so this is going to be from memory. But I think this question has been answered here before, so you might get lucky with a search.
The HF and Mid levels should be about equal. The LF needs some gain. A single cabinet needs about +6dB on the LF amplifier, a splayed pair or larger stack (due to LF coupling) a bit less. The HF driver is a 2426 so it benefits from a bit of boost above 10kHz, try something like +6 at 15kHz, about an octave wide or with a Q of 1.4, (or maybe a bit wider like a Q of 1 if it sounds better). Crossover points are 250 and 1500, 24dB Linkwitz. I can't remember the delays but the Mid and HF obviously need around 3ft to line up with the folded horn. HTH ps. there were a few different settings recommended at different times - but the standard Linkwitz was much preferred to an overlap. Edited by madboffin - 22 March 2017 at 8:08pm |
Pinyorouk
Thank you very much Madoffin. I will try these settings. Greatly appreciated. Mike
Brutus
Registered User Joined: 27 November 2015 Location: Utrecht,Holland Status: Offline Points: 101 |
those settings are in the settings file, on the martin audio website:
take a look! ;-)
Pinyorouk
Thanks Brutus, my VRS800 uses a JBL2426 1 Inch compression driver. Can you please advise whether the eq would be the same as that chart only covers the 1.4" driver? I know I should be using my ears too :)
Edited by Pinyorouk - 23 March 2017 at 2:38pm |
madboffin
You definitely won't need the narrow notch at 12k7, somebody did that to fix an odd peak in the EV driver response.
I only did the settings for the analogue crossover / controller - this was in 1986 or 87 before digital stuff became affordable. It was all done with B&K measuring kit (sweep oscillators & chart recorders) plus a TEF 10 (an early computerised measurement system). The only EQ we applied for the VRS800 was for the 2426, and as mentioned above it was just a boost at the top end. EQ for the LF is probably a matter of taste, and don't forget that 6dB boost doubles the amplifier power required. But the good thing about digital processors is that it's easy to make up a few different presets and decide which you prefer. Edited by madboffin - 23 March 2017 at 3:46pm |
Marko
Registered User Joined: 28 January 2009 Location: Croatia Status: Offline Points: 274 |
6 dB quadrouple the power!
Pinyorouk
Thanks for the clarification Madboffin. Great to have someone like yourself here who worked for Martin Audio.
Edited by Pinyorouk - 23 March 2017 at 10:18pm |
madboffin
Quite right, my apologies. Thanks Marko. |
