  New Posts New Posts RSS Feed - Martin B115
Martin B115
Father-Francis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Topic: Martin B115
    Posted: 09 November 2008 at 4:57pm
Martin B115 would you put these on top of Hogs??
Those who dance are thought to be crazy by those who don’t hear the music(+45 60322642 +254 712158396)
CLsystems View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CLsystems Quote  Post ReplyReply Direct Link To This Post Posted: 09 November 2008 at 5:20pm
you mean a 115 horn?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 09 November 2008 at 5:29pm
yes i mean the horn
Edited by Father-Francis - 09 November 2008 at 5:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CLsystems Quote  Post ReplyReply Direct Link To This Post Posted: 09 November 2008 at 5:53pm
im sure it will be fine, just get the delays right.
bitzo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 10 November 2008 at 8:35am
I use  martin 115 loaded with pd165 on 4 superscooper. What is the correct delay ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 14 November 2008 at 10:08am
I can´t find  the recommended driver which would be the best driver for this cab
Thanks Francis
ps they recommend Martin L1540 Embarrassed
Post Options Post Options   Thanks (0) Thanks(0)   Quote CLsystems Quote  Post ReplyReply Direct Link To This Post Posted: 14 November 2008 at 10:31am
you wont find the 'proper' driver anymore. Kappa pro works fine
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 14 November 2008 at 11:32am
can´t remember if it was here or else where someone said this was the bomb Rcf L15/554K
Edited by Father-Francis - 14 November 2008 at 11:32am
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 14 November 2008 at 11:41am
I use pd156 in that cab
Post Options Post Options   Thanks (0) Thanks(0)   Quote CLsystems Quote  Post ReplyReply Direct Link To This Post Posted: 14 November 2008 at 11:41pm
just remember, the cabinet was designed to work with lower power rated drivers, ive heard of someone who tried '1000w beymas' and had them fail on the first gig because they overheated. Fuzzylogic has PD1550 in some of his, and also jbl 2226. Kappa pros do work, and are cheap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 15 November 2008 at 12:33am
Cheers boss have them lying in boxes some where , so i´l just try them and get back to you
simo69 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote simo69 Quote  Post ReplyReply Direct Link To This Post Posted: 15 November 2008 at 6:21am
any pictures of the cabinet?
Forum Software by Web Wiz Forums® version 10.11
