Martin Destroyer x250 not working |
wangbag
Registered User Joined: 28 August 2011 Location: dirty south Status: Offline Points: 202 |
Posted: 10 April 2014 at 10:48am |
have 2 of these units, both are powering on one has light on the other doesn't, both gobo wheels move on startup but then stop and both mirror wheels have no movement at all but resistant to being turned when plugged in as if the motor is on but just not moving, any ideas to a fix or should i send them for repair?
Gwarn me some of dis.
wangbag
poked around and sorted it, turns out one bulb had a loose connection and the other one i think the mic is screwed 'cus it works in master/slave (being slave) but not sound to light.
yay
lgosdset
Young Croc Joined: 28 September 2010 Location: Reading ish Status: Offline Points: 1203 |
get a dry soft paintbrush and clean the little electret mic. I have found that this restores the sound to light function on my destroyers.
If the stepper motors go on these, it is pretty much game over as I can not find them new anywhere, you can try and loosen and wiggle the housing around, or buy old broken destroyers/punishers that have a problem with the PCB/lamp and nick the stepper motors out of them. |
lgosdset
just found this!
http://www.ebay.co.uk/itm/MARTIN-DESTROYER-GOBO-COLOUR-STEPPER-MOTOR-robo-scan-scanner-/121149312291?pt=UK_Sound_Vision_Other&hash=item1c350fcd23 woo. I can now get all of my destroyers working, but the cost of this motor is about the value of the fixture! so not really worth it. Edited by lgosdset - 10 April 2014 at 6:27pm |
col_b
Registered User Joined: 11 January 2010 Location: North West Status: Offline Points: 325 |
Got steppers for these in stock also, both new and used motors.
AV, Sound and Lighting and Laser Hire, Sales and Service. www.klsuk.com
