  New Posts New Posts RSS Feed - Martin WLX Plan request
 Post Reply Post Reply Page  <1234 5>
Bespoke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bespoke Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2008 at 3:54am
Originally posted by mykey mykey wrote:
This is a current design, Naughty! naughty! bit out of order my friend
Give me a Brazilain pounds and I'll give you the plans to something better
Plots ? Driver ?
mykey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2008 at 4:55am
Originally posted by ceharden ceharden wrote:
Mykey, just seen that pic and noticed you've got rid of the silly little central port on the Brute45 and stuck some proper sized ones in it! Tongue
Thats always been like that, the drawing before was to FOOL the Chinese
I must stop being paranoid LOL
I'll put up the original sketch in a min
I put the Arrows in for  AUDIO INTIMIDATION'S SAKE LOL
think that was up for long enoughSmile
Edited by mykey - 26 November 2008 at 6:27am
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2008 at 4:58am
you show me your's bespoke! and i'll show you mine!
I don't want to say too much about this bin, but to say I was over the moon would be a understatement
driver is a PDA1651
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2008 at 5:03am
getting back to the WLX, i keep looking at the specs and find them hard to belive, given the layout of the cab , and its size ETC
does anybody else want to comment on that, Cerharden, centauri , deadbeat, minimaxil, nineleaves anyone?????
Edited by mykey - 26 November 2008 at 11:45am
norty303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2008 at 1:11pm
Can someone explain why a letterbox shape is used rather than simply a circle or smaller diameter than the driver?  surely that would load the driver more evenly.
Also, taking that idea one stage further, has anyone ever made a cab where it has a circular exit from the front chamber, but turned this into a flared port (i'm thinking like a velocity stack on an inlet manifold here) with a view to smoothing the coupling into the main horn.
Or is  this just adding a an unneccessary horn within a horn?
Wrighty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wrighty Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2008 at 1:30pm
The letterbox is effectively the throat and it's easier when building a folded horn to expand from a rectangle than it is from a circle. Some creative fibreglassing might be the answer, but it would have to be very heavily braced and damped to prevent losses and/or resonances due to the high pressures involved at this point in the horn.
ALL YOUR BASS ARE BELONG TO US.
tomschute View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomschute Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2008 at 4:59pm
I see what you mean by effectively starting the horn / throat with a square - but as it is in effect suspended and not part of the horn then why not just make it circular?
www.stableaudio.co.uk
Speaker Building Services
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wrighty Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2008 at 5:08pm
It's not suspended (if it looks like the WSX plan I saw a while back) - the throat is the rectangular letter box and all expansion takes place from there. To expand from a circular cross section whilst transforming into a rectangular cross section (as you have with a folded horn) is more complex to achieve with plywood.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2008 at 5:36pm
the baffle looks like it's supended, but it's not
the horn tapers from the slot
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomschute Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2008 at 5:41pm
ah, now i get it
Heathrow_B_line View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heathrow_B_line Quote  Post ReplyReply Direct Link To This Post Posted: 28 November 2008 at 4:24pm
i stil need the wlx plan guys
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 29 November 2008 at 10:25am
TDA has them, he's built them already, I'm sure I saw some pictures
