  New Posts New Posts RSS Feed - Matrix U2000
Matrix U2000
kanks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kanks Quote  Post ReplyReply Direct Link To This Post Topic: Matrix U2000
    Posted: 26 April 2012 at 6:03pm
Hi ive got a Matrix U2000 in the old grey style 3U case. Its pcb is very similar to the STR2000 with the markings "MATRIX M2000 ARH" Its been a great amp but one of the young lads that came doing a show with me pluged the speakon conector comming from the Matrix into the turbosound link that was being powered by a crown macrotech at the time. So the Crown went into protect but unfortunatly the Matrix seems to have died. The front led's dont seem to do anything anymore.
Im a very much used to dealing with broken amps and have built many valve amps my self from scratch. Mosfet amps ive worked on normally camo down to being a few output fet's or a few caps but this seems it has a microcontroller in the from pcb. Ive done my fair share of micro programming in my time and would like to have a schematic to aid in replicating its fucntions should the need arrise. Im off now to check the voltage and see If I can get any signs of life from the micro.
I know that what has happend to the amp is to most including me a very stupid thing but the kids have to make mistakes from witch to learn but if anyone has had this issue before any input is very much welcome.
Cheers in advance Kris
AM55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AM55 Quote  Post ReplyReply Direct Link To This Post Posted: 26 April 2012 at 6:14pm
The designer/manufacturer Andy is member "andyamp" on here so might be worth a PM to him or he may well reply to your post.
A n t i m u t e   S o u n d   S y s t e m
Post Options Post Options   Thanks (0) Thanks(0)   Quote kanks Quote  Post ReplyReply Direct Link To This Post Posted: 26 April 2012 at 6:48pm
That will be a great if he can help. Ive just checked the voltage going to the pic16c71 micro and im only getting 1.3 volts and the pic16c71 needs 2.5 to 6 volts to run so im now trying to track down its regulator.
djeddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djeddie Quote  Post ReplyReply Direct Link To This Post Posted: 26 April 2012 at 9:25pm
Unfortunately you won't be able to PM andyamp until you've reached ten posts (or points), but hopefully he'll see the thread.
Chas n Dave : it's like Drum and Bass but with beards.
E=mc² ±3dB
Post Options Post Options   Thanks (0) Thanks(0)   Quote kanks Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2012 at 2:07pm
Just to let people know how I got on with this. I found that one of the relays had been destroyed and the 5 volt rail was shorted somehow inside. Removed the relay and the amp jumped back to life but the db meter dosnt work but I think ths because the micro on the fron panel is dead. It gets good signals for left and right to the ADC channels but the micro dosnt drive the leds. Anyway on the scope the amp runs identical right upto clip both sides and the clip lights still work so its looking like its lived to fight another day. I may even program a new microcontroller to do the output metering myself when I get some time. Anyway now im on to working on a macrotech 1200 thats got a shorted bank of transistors.
cilla.scope View Drop Down
Legs all the way to her bottom....
Post Options Post Options   Thanks (0) Thanks(0)   Quote cilla.scope Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2012 at 1:45am
send him an email, I think theres an email address on his website http://www.matrixamplification.com/
I know he was having a clear out recently .. if you want a LED driver board, this may be a good time to get in touch before the skip man commeth!!
My girlfriend thinks I'm a stalker.
Well, she's not exactly my girlfriend yet ...
Post Options Post Options   Thanks (0) Thanks(0)   Quote kanks Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2012 at 4:47pm
Just sent them a email will see if they get back to me.Thank for the heads up
web department
