Mc2 e45 |
munkey
Registered User Joined: 17 August 2011 Status: Offline Points: 300 |
Posted: 18 January 2017 at 11:09am |
Mc2 e45 produces 2500 @ 4ohm and 4200 a 2ohm. How much power is available at 2.66 ohm
Cheers |
the midtops!
B_Bender
Registered User Joined: 28 October 2016 Location: Surrey Status: Offline Points: 118 |
somewhere in between
Earplug
A bit less than you get at 2 ohm.
I wouldn´t get too hung up with power figures. The impedence of your speaker is a moving target, depending on the frequency. Then add in cable resistance, etc. The important thing to know is if the amp is actually stable below 4 ohms, which it obviously is. IMHO, few dB´s of power here or there is not the most important factor. Sensibility, efficiency and power compression are far more important. |
It would be around 3000 - 3300 watts. Best Regards, |
cravings
what do you want to do with it? they're pretty good with 3 drivers a side.
munkey
Running 12 punishers with a pair. I'm not convinced they'll have enough power tbh.
the midtops!
m0gsi
Registered User Joined: 09 February 2015 Status: Offline Points: 99 |
We tried an E90 at 2.6ohm on 3 1851s and found it quite lacking.
Edited by m0gsi - 19 January 2017 at 1:58pm |
