  New Posts New Posts RSS Feed - MC2 vs QSC Powerlight
Stray-Sounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stray-Sounds Quote  Post ReplyReply Direct Link To This Post Topic: MC2 vs QSC Powerlight
    Posted: 01 May 2015 at 6:19pm
We've bought a logic system VA rig and need amps. Our options are MC2 E45s or QSC Powerlight equivalent.
Could people share their opinions on these amps?
The QSC are much cheaper, are they as good at the mc2?
Many thanks :)
csg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote csg Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2015 at 8:55pm
PL3 series?
If so, they are very good amps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stray-Sounds Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2015 at 9:17pm
Yes, pl380.
Don't spose you know how they compare to an E45?
csg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote csg Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2015 at 9:19pm
both are great bits of kit, i would probably go with the 380, particularly if it is cheaper.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stray-Sounds Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2015 at 9:28pm
Thanks. I think we'll have to find a way to try both!
Liteworks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Liteworks Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2015 at 11:32pm
PL380's are good solid amps, very similar power wise to E45's so a good alternative.
Not heard the E45's in direct comparison so can't comment on any differences (or not), but happy with our PL380's (we use for everything from Mid & Low in 3way tops, full range monitors and Sub's).
-m
www.Lite-Works.co.uk
My Kettle is 2000w! why isn't it very loud??
bmw28 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bmw28 Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2015 at 1:47am
Is there is any major difference other than power between PL2 & PL3 series ... using PL 236 on hi/mids at the moment...
csg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote csg Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2015 at 7:57am
for me, not enough to make a change if you have enough headroom on the 236.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Liteworks Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2015 at 9:57am
Not much if any difference really, they've both the same (or very similar) I/O options on the back of the amp's.  The PL325 and PL340 are similar design and power output to the the PL2 range.
The only major difference is the PL380's are a different design and a lot higher power point than any of the PL2's.
-m
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stray-Sounds Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2015 at 10:00am
Okay thanks. Another thought.. How does the MC2 E100 compare to a Lab FP10000q ?? I'm aware of power rantings differences on paper but wondering how they compare in real life?
Thanks
londonavc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote londonavc Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2015 at 8:28pm
I have used both, especially the PL380s, used MC2 E45,90,100.
I would personally go with the QSC's. It would be interesting to do a direct comparison.
The QSCs will save you a lot of money too...
Typically now a PL380 is around £2500.
Whereas a MC2 E90 £3500.
Both come with 5 year warranty I'm sure, MC2 is UK based. Excellent cs.
4AC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4AC Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2015 at 3:30pm
Why? Have you compared both sonically?
Or £715 used (ex shipping to UK): http://soundsale.nl/occasions/product/1151/pl380
Ridiculously cheap.
uǝɿɿɐʌǝ6ɯo sı ʇsʞǝʇ ǝzǝp
