Mega-Kick MK412 by Amano |
Post Reply | Page 123> |
Amano
Registered User Joined: 06 October 2008 Location: Russia Status: Offline Points: 219 |
Posted: 26 October 2009 at 7:28am |
It's my new project of most powerful and smallest KICK-cab.
Dimensions: 750x750x550mm...
mykey
Nice when you say powerfull, you mean HIGH wattage?
it's not very load for a 4 x 12"?
or am I missing something here
Amano
i mean 4x600Watts=2400 watts per cab and high SPL! |
Amano
One amp for one cab for 4 ohm per channel impedance...
or...in 2 ohms usage one powerful amp for two cabs...
mykey
I would hope neo drivers?
will be nice and quick, what with it being 12's and tight/small chamber
Amano
QSC RMX 5050 can be great decision for 2 ohm usage...
i modelled it for P-Audio E-13LF drivers... but you can try to put other NEO driver |
Amano
P-Audio E-12LF is CHEAPEST driver for this cab
Amano
It needs a radiator to cool air inside chamber... or similar decision like in 12pi cab ...
mykey
group delay is low, displacement is low
it's size lets it down
what driver?
Amano
Try Beyma 12P1000Nd
Approximately weight: 5.4kg x 4 + Wood mass + Radiators mass ~ 22kg + 30kg~
52kg
You'll forget 15"s and 18"s kick cabs with this one cab to support sub-bass cabs...
It needs something like infra-bass below 80Hz... Edited by Amano - 26 October 2009 at 9:21am |
skippyboy
New Member Joined: 11 July 2008 Location: AUSTRALIA Status: Offline Points: 5 |
Hi Amano
Sorry to jump in on this thread, just wondered how the "2x18" meatgrinders v2" testing and plans turned out. anything forthcoming? Cheers Rob |
james folkes
Old Croc Joined: 08 January 2005 Location: United Kingdom Status: Offline Points: 3064 |
nice... i have 215 and 218 cabs that use this layout, they strike me as a really good use of space and are an inherently good way of getting path length without 180 degree bends in the horn.
i really wanted to use the layout in some kind of mid-top enclosure, only 2 x 12"s in a trap box, but then you'd use at least 2 a side anyway so you'd be looking at similar performance. back in the day, ideas looked like this. your rather excellent design does make me want to consider re-visiting this concept, that said it'd probably be just as sensible to stick mid-high enclosures on top of these boxes, ground stacking requires height on the mid and high; if you were making a flown point source cluster mid-top though... hmm... james. |
mardy hippy.
