  New Posts New Posts RSS Feed - MHB 4818 Simulation
MHB 4818 Simulation
jaya000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaya000 Quote  Post ReplyReply Direct Link To This Post Topic: MHB 4818 Simulation
    Posted: 16 September 2012 at 6:30am
I want to use this cabinet to match speaker i have.
I want guidance for hornresp input.
I have done but i think i need some guidance specially for ATC.
Please tell me if my hornresp inputs are correct or not?
So i need guidance from experts
_djk_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2012 at 10:31am
A MHB 4818 is a box, what is the driver?
djk
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaya000 Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2012 at 10:59am
Thanks DJK.
The driver is Chinese made. I have tested it for thiel-small parameters with LMS.
Fs : 34.86
Qms : 21.68
Qes Z: 0.32
Qts : 0.318
Vas : 171.86
Re : 5.0 ohm
Sd. 1195
Mmd : 222.24
Lerc 3.41
Cms 84.75
Spl 95.4
BL : 28.9
This is with 4 layer voice coil.
Any mistakes?
Peter Jan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peter Jan Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2012 at 12:31pm
Looking at the figures and if they are correct (seems okay with the sensitiviy figure not exagerated), it seems like a decent low driver that may have an Xmax of around 8mm or something. But what respons are you after ? Do you have these 4818 already made and look for a suitable driver or do you have drivers and look for a cabinet to put them in or is everything at this point just a start from scratch ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2012 at 12:50pm
That looks like a very good driver for the MHB 4818 (Keele W-bin).
djk
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaya000 Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2012 at 4:56pm
I have the driver. So looking for the cabinet.
In my country W bin is quite popular, hence was checking the same for driver i have.
Thanks djk,
you are always helpful.
My hornresp input is ok?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peter Jan Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2012 at 5:07pm
Atc looks about right, depending on what you considder as being the compression chamber and the throat or the onset of the horn, but I can't see Vtc being 30 liter, that should be less.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaya000 Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2012 at 5:17pm
Thanks Peter Jan,
I calculated the area marked as Vtc.
The calculation is as under
42.07 width till horn starts
10.6 height
57.4 depth of the box.
so it calculated as 42.07 x 10.6 x 57.4 = 25597 + added speaker volume 4403.
So i rounded as 30000.
The triangle volume i adjusted towards round cutout of plywood .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peter Jan Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2012 at 5:48pm
The baffle is roughly 33cm x 33cm or ~1100cm² where the horn begin, so S1=1140 as you put it in, was a good starting point. It's a bit hard to determin where the the compression chamber truelly ends and the horn begins, but it's certainly not much more than the volume the speaker cone encloses up to the mounting baffle or a bit more than that 4,4 liter.
geraelec2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote geraelec2 Quote  Post ReplyReply Direct Link To This Post Posted: 03 July 2015 at 7:35pm
Thanks Peter Jan,
10.6 height
Hi. I loved all the tips and information given in this post, thanks to everyone. In other business, is there any chance to get the image with a better resolution? Please, thanks in advance.
sn95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sn95 Quote  Post ReplyReply Direct Link To This Post Posted: 03 July 2015 at 8:26pm
YES free speaker plans or free horn plans
mhtplsh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mhtplsh Quote  Post ReplyReply Direct Link To This Post Posted: 18 June 2017 at 5:24pm
Sorry sn95. i saw it today so posting today.
uploads/2632/MHB_4818_LIKE_W_BIN_box.pdf
