MHL-250 |
floroworld
Registered User Joined: 13 February 2006 Location: Portugal Status: Offline Points: 54 |
Posted: 02 July 2015 at 9:53pm |
hi need a lamp for a old Chauvet Shadow 250 (TFX-250BL0 ) its a MHL 250 double-ended metal halide opx 67mm long can any one help cheers
www.floroworld.com
csg
search for wildfire UV fixtures, these use very similar lamps, i think the chauvet is a copy of their 250w fixture.
floroworld
Hi thanks for that............daft question what voltage would the lamp be when I phoned chauvet they THINK it will be 240v UK..... they sold this unit here and in USA.... cheers
www.floroworld.com
csg
the lamp wont differ between locations - as it is a discharge lamp only the control gear will differ. I should imagine the arc voltage is around 90V on a 250w lamp.
By the sound of it, who ever you talked to at Chauvet does not sound like they know what they are talking about.
in short, a US lamp will work fine in a european unit as the voltage is corrected by the unit. |
floroworld
hi the ones I found are 125v so that sounds about right but they are not cheep the wildfire stuff looks well cool thanks for your help
www.floroworld.com
